1 Reply Latest reply on Sep 5, 2007 1:18 PM by Gorka Ludlow
    Best Method for Strechable .swf file in horizontal but not vertical?
      What is the best method to create an easy to use flash file that will allow horizontal scaling with a fixed vertical size?
      This will be for a blog header in a variable width design at Make Light Real.com
      I have tried the basic stage properties and found StageScaleMode.NO_BORDER to be an ok solution, but I'm not sure what will happen when I begin to drop active clips in on the stage. Will the stage operate from a fixed point or how will the clips orient to the stage as it expands?
      My understanding of actionscript is just enough to hack pieces of what I need together: but if you could enlighten me with the most basic understanding of which method would work best for me I'd apprecate it. I also have this method to alter the background (as a clip):
      // function which replaces all the elements with the new values
      slide = function () {
      photo_mc._x = 0;
      photo_mc._y = 0;
      photo_mc._width = Stage.width;
      photo_mc._height = Stage.width/rapp;
      if (photo_mc._height<Stage.height) {
      photo_mc._height = Stage.height;
      photo_mc._width = Stage.height*rapp;
      Should I just alter the variables there to lock the stage height?
      Thanks for your time in answering.
