3 Replies Latest reply: Mar 2, 2010 3:32 AM by SE_0208 RSS
    Stream.onStatus event notifications
    Syberkitten Community Member
      We've encountered conceptual difficulties figuring out which stream
      is currently being played / started / finished using the onStatus handler for the
      Stream Object.
      The documentation it is written that the only event which returns details about
      the stream currently being played is "NetStream.Play.Start"
      This is very peculiar and does not allow internal monitoring of
      finished streams...
      We are creating dynamic playlists on the FMS and there is
      a need to know which stream has just finished playing, not only
      a general notification that A stream stopped playing such as
      NetStream.Play.Completed or NetStream.Play.Switch (returned from the onPlayStatus handler
      of the Stream object)
      The best solution would be, to be able to define a custom
      handler function to be executed at the end of playing a certain
      stream (live or recorded) which will allow perfect
      action being taken when the stream reaches its designated end.
      for example:
      myStream.play("stream name", 10, -1,false,myFunction);
      where myFunction would be a customer handler evoked when the stream
      reaches its end on the server's playlist Queue.
      Is there a way to accomplish the above using FMS 3.5.0 - 3.5.3?
        • 1. Re: Stream.onStatus event notifications
          Janaki Lakshmikanthan Employee Hosts
          NetStream.play() method does not allow you to take the extra parameter to call a custom method. Using the status messages like "NetStream.Play.Start" and "NetStream.Play.Stop", you will have to call your custom method to monitor the streams in the playlist.
          Regards,
          Janaki L
          • 2. Re: Stream.onStatus event notifications
            we are switching between a main stream and smaller streams which are ads,
            generating alot of Stop / Start / Completed / Switch Events which do not
            signify the actual "finish" of a stream.
            a 20 min stream switched in the middle will send all the above events when resumed / started
            /finished, so its impossible to really know when the stream actually finished and
            assume an action.
            let me explain, how we create a playlist:
            mainStream1.flv - is 10 min stream.
            1. starting the stream s.play("mainStream1.flv",0, 100,false) - playing it for 100 seconds
            2. s.play("ad1.flv",0,-1,false) - playing an ad after 100 seconds played on the first stream
            3. s.play("mainStream1.flv",100,200,false) - resuming the main stream from 100 till 200, after ad1.flv finished
            4. s.play("ad2.flv",0,-1,false) - playing another ad when the main item reaches second 200
            5. s.play("mainStream1.flv",200,-1,false) - resuming the main stream when the ad finished
            now, in the code, the above scenario would look like this:
            s.play("mainStream1.flv",0, 100,false);
            s.play("ad1.flv",0,-1,false);
            s.play("mainStream1.flv",100,200,false);
            s.play("ad2.flv",0,-1,false);
            s.play("mainStream1.flv",200,-1,false);
            FMS sends 3 Completed Events for the mainStream1.flv. 3 started events
            and 2 Switch events.
            I hope the above explicates the difficulty i'm implying....
            • 3. Re: Stream.onStatus event notifications
              SE_0208 Adobe Employee
              With respect to your example, Play.Stop would be issued only once and hence you can conclude that stream had stopped. I suppose that should solve your problem, have you tried that. If there is something else you want, please let us know.
