• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
CFMail breaks up attachments filename with non ASCII
Guest
Sep 07, 2007 Sep 07, 2007
Hi CF-Devs out there!
My problem is, that when attaching files via cfmailparam - no matter if inline or not - and using a filename that contains or a non 7bit-ASCII character or a simple space, the filename is not displayed correctly in Outlook nor Thunderbird. I am sure that this topic has been discussed here earlier but I really don't find any topic when using the Forum Search function... so please help anyway :) I am still using CFMX 6.1 😞
My code is the following:
<cfmailparam type="#variables.attachments .getContentType()#"
file="#variables.attachments
.getFilename()#"
disposition="#this.dispositionType(variables.attachments .isInline())#"
contentID = "#variables.attachments
.getCid()#">
When I revise the generated email code then I find the following:
Content-Type: application/octet-stream
Content-Transfer-Encoding: base64
Content-Disposition: attachment; filename*2=nger.csv; filename*0*=UTF-8''emailempf; filename*1*=%c3%a4
Content-ID: <DEE13419-D022-9396-C8A4DF2AAAA7C4EF>
You can see that the filename (emailempfänger.csv) breaks up into several pieces which according to
RFC 2231 is a valid format but obviously is not interpreted correctly by e.g. Outlook. Or am I missing something else?
I would appreciate your help. Thanks in advance.
Buergermeister
TOPICS
Advanced techniques
Views
413
Translate
Translate
Report
Report
Community guidelines
community guidelines
Guest
I tried the following and it worked for me:
<cfmailparam file="C:\Detail.xls" type="text" >
in cfmail tag.
Please send the optional values that you are using for the following
1) variables.attachments.getContentType()
2)variables.attachments.getFilename()
3)this.dispositionType(variables.attachments.isInline())
4)variables.attachments.getCid()
jJ
Votes
Translate
Translate
Report
Report
Guest
LATEST
The filename you used does not contain any non 7bit ASCII character. The problem only occurs if I use characters like "ä","ö","ü" but even [space] does provoke the error.
The variables hold the following values (you can see them in the source posted, too):
1) variables.attachments.getContentType() : application/octet-stream
2) variables.attachments.getFilename() : [AbsoluteFilePath]/emailempfänger.csv
3) this.dispositionType(variables.attachments.isInline()) : attachment
4) variables.attachments.getCid(): DEE13419-D022-9396-C8A4DF2AAAA7C4EF
Cheers!
Votes
Translate
Translate
Report
Report
Resources
Documentation
