5 Replies Latest reply on Mar 2, 2010 2:54 PM by Harm Millaard
    Media Encoder "Could not write XMP data in output file." issue
    fiercev27
      Greetings,
           We have invested a great deal of money and time into a brand new editting system and we need some help with adobe media encoder. We are trying to export some of our projects and we keep getting the same error. Here is the entire log of errors:
      - Source File: C:\Users\Ramius\AppData\Local\Temp\Acura Spot 011410_CS4_1_6.prproj
      - Output File: M:\acura_rooftop_43_draft_1.avi
      - Preset Used: NTSC DV
      - Video: 720x480, 29.97 [fps], Lower, Quality 100
      - Audio: 48000 Hz, Stereo, 16 bit
      - Bitrate:
      - Encoding Time: 00:17:23
      2/4/2010 1:42:28 PM : Encoding Failed
      Error compiling movie.
      Unknown error.
      - Source File: C:\Users\Ramius\AppData\Local\Temp\Acura Spot 011410_CS4_1_7.prproj
      - Output File: C:\Users\Ramius\Desktop\acura_rooftop_43draft_1.avi
      - Bitrate:
      - Encoding Time: 00:02:09
      2/4/2010 1:54:21 PM : Encoding Failed
      The Operation was interrupted by user
      - Source File: C:\Users\Ramius\AppData\Local\Temp\Acura Spot 011410_CS4_1_9.prproj
      - Bitrate:
      - Encoding Time: 00:16:04
      2/4/2010 2:19:49 PM : Encoding Failed
      Unknown error.
      - Source File: C:\Users\Ramius\AppData\Local\Temp\Acura Spot 011410_CS4_1_10.prproj
      - Output File: C:\Users\Ramius\Desktop\acura_rooftop_HD_draft_1.mp4
      - Preset Used: HDTV 1080p 29.97 High Quality
      - Video: NTSC, 1920x1080, 29.97 [fps], Progressive
      - Audio: AAC, 160 [kbps], 48 kHz, Stereo
      - Bitrate: VBR, 1 Pass, Target 32.00, Max 40.00 [Mbps]
      - Encoding Time: 00:01:38
      2/4/2010 2:30:31 PM : Encoding Failed
      - Source File: C:\Users\Ramius\AppData\Local\Temp\Acura Spot 011410_CS4_1_11.prproj
      - Output File: C:\Users\Ramius\Desktop\acura_HD.mp4
      - Encoding Time: 00:00:38
      2/4/2010 3:19:31 PM : Encoding Failed
      - Source File: C:\Users\Ramius\AppData\Local\Temp\Acura Spot 011410_CS4_1_12.prproj
      - Output File: C:\Users\Ramius\Desktop\acura_HD.avi
      - Bitrate:
      - Encoding Time: 00:01:08
      2/4/2010 3:31:37 PM : Encoding Failed
      - Source File: C:\Users\Ramius\AppData\Local\Temp\Acura Spot 011410_CS4_1_17.prproj
      - Bitrate:
      - Encoding Time: 00:15:31
      2/4/2010 4:21:06 PM : Encoding Failed
      Unknown error.
      - Source File: C:\Users\Ramius\AppData\Local\Temp\Acura Spot 011410_CS4_1_19.prproj
      - Output File: M:\GRAPHICS\cow_graphics\acura_HD.mp4
      - Encoding Time: 00:00:24
      2/4/2010 5:16:54 PM : Encoding Failed
      - Source File: C:\Users\Ramius\AppData\Local\Temp\ihigh_CS4_HD_16.prproj
      - Output File: C:\Users\Ramius\Desktop\mxf.mpg
      - Preset Used: 1440 x 1080i 29.97 High Quality
      - Video: NTSC, 1440x1080, 29.97 drop frame [fps], Upper, Quality 4.0
      - Audio: 384 [kbps], 48 kHz, 16 bit, Stereo, MPEG
      - Bitrate: VBR, 1 Pass, Min 4.00, Target 15.00, Max 18.50 [Mbps]
      - Encoding Time: 00:05:08
      2/23/2010 12:12:40 PM : Encoding Failed
      Unknown error.
      - Source File: C:\Users\Ramius\AppData\Local\Temp\ihigh_CS4_HD_18.prproj
      - Output File: M:\AVI\ihigh_avi\GAR\Marines\marinespromo_2009.avi
      - Bitrate:
      - Encoding Time: 00:04:00
      2/23/2010 12:26:54 PM : Encoding Failed
      Unknown error.
      - Source File: C:\Users\Ramius\AppData\Local\Temp\ihigh_CS4_HD_19.prproj
      - Bitrate:
      2/23/2010 12:51:01 PM : Encoding Failed
      Unknown error.
      - Source File: C:\Users\Ramius\AppData\Local\Temp\ihigh_CS4_HD_23.prproj
      - Output File: C:\Users\Ramius\Desktop\allhdtest2.mpg
      - Encoding Time: 00:04:20
      2/23/2010 4:23:46 PM : Encoding Failed
      Unknown error.
      - Source File: C:\Users\Ramius\AppData\Local\Temp\ihigh_CS4_HD_27.prproj
      - Output File: C:\Users\Ramius\Desktop\Sequence 07.mp4
      - Encoding Time: 00:09:11
      3/2/2010 3:21:19 PM : Encoding Failed
      Unknown error.
      - Source File: C:\Users\Ramius\AppData\Local\Temp\ihigh_CS4_HD_28.prproj
      - Output File: C:\Users\Ramius\Desktop\Sequence 07_1.mp4
      - Encoding Time: 00:09:00
      3/2/2010 3:34:47 PM : Encoding Failed
      Unknown error.
      - Source File: C:\Users\Ramius\AppData\Local\Temp\ihigh_CS4_HD_29.prproj
      - Output File: C:\Users\Ramius\Desktop\Sequence 07_2.mp4
      - Encoding Time: 00:10:22
      3/2/2010 4:41:03 PM : Encoding Failed
      Unknown error.
      We absolutely need to fix this issue ASAP, we are in a major bind until we can resolve this issue. Thanks a bunch.
