4 Replies Latest reply on Mar 3, 2010 11:59 AM by shooternz
    Stills Exporting with an Unwanted Transition
    pzkevco
      I am using Adobe Premiere Pro CS4 4.2.1.
      I primarily build slide shows with stills.  I have built many with previous versions of Premiere.  I built one in the fall using CS4 (not 4.2.1 - I justed updated it).  I don't use the Automate to Sequence feature.  I drag and drop each still in by hand.
      Tonight I have run into a major problem.  I use very few transitions between stills, but the export (in QuickTime) has a short dissolve between every still.  I have not encountered this before.  When I render the Work Area - I do not see them.  Only in the exported QuickTime file.
      Any information would be appreciated.
      Thank you,
      Kevin
