1 Reply Latest reply on Aug 31, 2007 8:16 PM by awilber
    flex sending corrupt SOAP request
    awilber
      I've created a PHP5 SOAP webservice and am trying to call a method from flex. I get a fault from the Flex app that says
      faultString="HTTP request error" faultCode="Server.Error.Request"
      The SOAP request received by the server is as follows (which I think explains why the server responded with an error):
      <SOAP-ENV:Envelope xmlns:SOAP-ENV=" http://schemas.xmlsoap.org/soap/envelope/" xmlns:xsd=" http://www.w3.org/2001/XMLSchema" xmlns:xsi=" http://www.w3.org/2001/XMLSchema-instance">
      <SOAP-ENV:Body/>
      </SOAP-ENV:Envelope>
      It is missing all the body parameters. What could cause an empty request like this?
      The relevant AS:
      public var _webServiceLoaded:Boolean = false; // flag noting when wsdl has been loaded
      public var _myService:WebService = new WebService();
      public function initWS():void {
      _myService.wsdl = " http://foreignserver.com/seminar_service.wsdl";
      _myService.loadWSDL();
      _myService.echoArgs.addEventListener("result", echoResultHandler);
      _myService.addEventListener("fault", faultHandler);
      _myService.addEventListener('load',WSLoad);
      public function send_attendee_email():void {
      _myService.echoo("qwerty"); // should just return the same string we send; echoo spelled with extra o
      And my wsdl:
      <?xml version="1.0"?>
      <definitions
      xmlns=" http://schemas.xmlsoap.org/wsdl/"
      xmlns:tns=" http://foreignserver.com/seminar_service.php"
      xmlns:soap=" http://schemas.xmlsoap.org/wsdl/soap/"
      xmlns:wsdl=" http://schemas.xmlsoap.org/wsdl/"
      xmlns:soapenc=" http://schemas.xmlsoap.org/soap/encoding/"
      targetNamespace=" http://foreignserver.com/seminar_service.php">
      <message name="echooInput">
      <part name="echo" type="xsd:string"/>
      </message>
      <message name="send_attendee_emailInput">
      <part name="sem_date" type="xsd:string"/>
      <part name="sem_first" type="xsd:string"/>
      <part name="sem_last" type="xsd:string"/>
      <part name="sem_title" type="xsd:string"/>
      <part name="sem_company" type="xsd:string"/>
      <part name="sem_phone" type="xsd:string"/>
      <part name="sem_email" type="xsd:string"/>
      <part name="pdf_filename" type="xsd:string"/>
      </message>
      <message name="echooOutput">
      <part name="return" type="xsd:string"/>
      </message>
      <message name="send_attendee_emailOutput">
      </message>
      <portType name="seminarPortType">
      <operation name="echoo">
      <input message="tns:echooInput"/>
      <output message="tns:echooOutput"/>
      </operation>
      <operation name="send_attendee_email">
      <input message="tns:send_attendee_emailInput"/>
      <output message="tns:send_attendee_emailOutput"/>
      </operation>
      </portType>
      <binding name="seminarBinding" type="tns:seminarPortType">
      <soap:binding xmlns=" http://schemas.xmlsoap.org/wsdl/soap/" style="rpc" transport=" http://schemas.xmlsoap.org/soap/http"/>
      <operation xmlns:default=" http://schemas.xmlsoap.org/wsdl/soap/" name="echoo">
      <input xmlns:default=" http://schemas.xmlsoap.org/wsdl/soap/">
      <soap:body xmlns=" http://schemas.xmlsoap.org/wsdl/soap/" use="encoded" encodingStyle=" http://schemas.xmlsoap.org/soap/encoding/"/>
      </input>
      <output xmlns:default=" http://schemas.xmlsoap.org/wsdl/soap/">
      </output>
      </operation>
      <operation xmlns:default=" http://schemas.xmlsoap.org/wsdl/soap/" name="send_attendee_email">
      </input>
      </output>
      </operation>
      </binding>
      <service name="seminarService">
      <port xmlns:default=" http://schemas.xmlsoap.org/wsdl/soap/" name="seminarPort" binding="tns:seminarBinding">
      <soap:address xmlns=" http://schemas.xmlsoap.org/wsdl/soap/" location=" http://foreignserver.com/seminar_service.php"/>
      </port>
      </service>
      </definitions>
