9 Replies Latest reply on Mar 14, 2010 11:58 AM by AdobeScripts
    Find-Change GREP scrambles text formatting
    Kasyan Servetsky Level 5
      It happens if I do this in InDesign and by script.
      Here is what I have before the search:
      and these are my settings
      and this is what I've finally got – all formatting has moved by 6 characters to the right.
      Any ideas how to avoid this?
      Kasyan
        • 1. Re: Find-Change GREP scrambles text formatting
          I've found a workaround: first find and move text, then get rid of tags.
          MoveTaggedText();
          function MoveTaggedText() {
              app.findGrepPreferences = app.changeGrepPreferences = NothingEnum.nothing;
              app.findGrepPreferences.findWhat = "\\{head\\}.+\\{\\/head\\}\\r";
              var myFinds = myDoc.findGrep();
              var myFound = myFinds[0];
              var myTextFrame = myDoc.textFrames.itemByName("head");
              if (myTextFrame != null) {
                  myFound.move(LocationOptions.BEFORE, myTextFrame.texts[0]);
                  app.findGrepPreferences.findWhat = "\\{\\/?head\\}";
                  app.changeGrepPreferences.changeTo = "";
                  myTextFrame.changeGrep();
          But I still wonder why it happens.
          • 2. Re: Find-Change GREP scrambles text formatting
            That's a familiar one. No idea what causes it -- some random variations show that this does work
            \{head\}(.+?)
            and this does not(!)
            \{head\}(.+)
            (and neither one works with something after the wildcard set).
            No work-around using GREP, but you can of course first remove {head} then {/head} with regular Find-Change. If it's in a script, two dumb operations instead of one a bit too smart doesn't hurt.
            • 3. Re: Find-Change GREP scrambles text formatting
              Thanks, Jongware.
              I solved this with two find-change grep operations.
              Kasyan
              • 4. Re: Find-Change GREP scrambles text formatting
                AdobeScripts Level 3
                How InDesign will know WHICH part of text you want to replace ?
                GREP in InDesign work on text as string - without formatting ...
                So in your case - replaces $1$2$3 with $2 contents.
                Yes, would be better if it will work on Text objects ... and in your case - copy/cut $2 contents, then select $1$2$3 and place $2 contents with formatting.
                robin
                www.adobescripts.com
                • 5. Re: Find-Change GREP scrambles text formatting
                  or only one:
                  \{\/*head\}
                  robin
                  • 6. Re: Find-Change GREP scrambles text formatting
                    Thank you, Robin.
                    A single find-change grep operation scrambles formatting too. Here is how I solved this.
                    Kasyan
                    app.findGrepPreferences.findWhat = "(?s)<" + myTag + ">.+</" + myTag + ">\\r?";
                    if (myFound != undefined) {
                         var myTextFrame = myDoc.textFrames.itemByName(myTag);
                              myFound.move(LocationOptions.BEFORE, myTextFrame);
                              app.findGrepPreferences.findWhat = "</?" + myTag + ">";
                              myTextFrame.texts[0].applyParagraphStyle(myDoc.paragraphStyles.item(myTag), false);
                    • 7. Re: Find-Change GREP scrambles text formatting
                      But if you know the names of your Tags - why you don't use regular Find/Change ?
                      Shouldn't be faster ?
                      robin
                      • 8. Re: Find-Change GREP scrambles text formatting
                        This is only a part of the script that finds text between tags, moves it to another text frame and finally removes the tags.
                        Kasyan
                        • 9. Re: Find-Change GREP scrambles text formatting
                          You can use Positive Lookbehind and Positive Lookahead:
                          (?<=\{tag\})(.+)(?=\{\/tag\})
                          This will return only (.+) ... but it will be the text from first {tag} in text to last {/tag} in text ...
                          update:
                          This one is better - but you also need to add :,; and other punctuations and symbols ...
                          (?<=\{tag\})[\d\l\u\s\w,:'"]*(?=\{\/tag\})
                          update:
                          I don't know what was wrong before - but this work as expected:
                          (?<=\{tag\}).+?(?=\{\/tag\})
                          update:
                          This will find multi-paragraph texts:
                          (?<=\{tag\})(.\r*)*?(?=\{\/tag\})
                          robin
