4 Replies Latest reply on Mar 3, 2010 7:26 AM by Shock_Terminal
    Project won't load all of a sudden in PP CS4
    Shock_Terminal
      I am having a big problem.
      I have a project that is about 30 min long (6mb) and it gets to %98 or so and then freezes.
      Problem started after a night I set up a render, the next morning realized I forgot to turn an audio track back on.
      So I turned it on and set up the render again, when I came home the render had failed so I tried again with the same results.
      Then I rebooted to see if that would fix it, well it made things worse as now the project just will not open.
      Things I have tried:
      -Opening Auto-save (all 5)
      -Hiding assists
      -Opening project on another machine (several)
      -Importing Project to Premiere
      -XML Wrench
      I did get the project to import into After Effects and then export as a Premiere project.
      This kinda worked as I got my timeline back so I was just gonna try to work with that, however:
      -Manny clips are a few frames off (position and/or length, some are even like 1/2 a frame off somehow)
      -Every clip is a linked AE file
      -Sound levels are all over the place
      -when I try to tell it to replace clip with the original file it pulls from wrong section or gives an error
      -I already had Linked AE files so those are really goofy
      I am pulling my hair out trying to fix this.
      I would REALLY like to get this project file working again as the last version is 2 weeks old.
      Any ideas or advice?
