1 Reply Latest reply on Mar 3, 2010 10:16 AM by MrFork
    Using The Summary Function in ADG
    MrFork
      Hello All,
      Please see my code below. Im using the advance data grid to create a summary row. The summary row currenty SUMs up the 'unqiuevists' and 'redemptions' columns and all is working well.
      What i want to do is then create a 3rd row called 'conversion rate' this conversion rate is a calculation between the uniquevisits and the redemptions columns. If you review the code at the bottom I have managed to create a custom summary func and that function seems to be working fine (using trace)..
      However, I cannot then get the calculated result back into the advance data grid, am i missing something really obvious or is what Im trying to do not possible using the summary row function?
      Please try and help, Ive been on this for days!
      <?xml version="1.0"?>
      <!-- dpcontrols/adg/SummaryGroupADGCustomSummary.mxml -->
      <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml" initialize="createGrouping(dpFlat)">
          <mx:Script>
              <![CDATA[
                  import mx.collections.GroupingField;
                  import mx.collections.Grouping;
                  import mx.collections.SummaryField;
                  import mx.collections.SummaryRow;
                  import mx.collections.GroupingCollection;
                  import mx.collections.ArrayCollection;
                  import mx.controls.advancedDataGridClasses.AdvancedDataGridColumn;
                  import mx.collections.IViewCursor;
                  import mx.collections.SummaryObject;
                  private var groupingCollection:GroupingCollection = new GroupingCollection();
                  private function createGrouping(tmpArray:ArrayCollection):GroupingCollection
                      groupingCollection.source = tmpArray;
                      var summaryRow:SummaryRow = new SummaryRow;
                      var summaryField:SummaryField = new SummaryField;
                      summaryField.dataField="redemptions";
                      summaryField.operation="SUM";
                      var summaryField1:SummaryField = new SummaryField;
                      summaryField1.dataField="newvisits";
                      summaryField1.operation="SUM";
                      var summaryField2:SummaryField = new SummaryField;
                      summaryField2.dataField="conversionrate";
                      summaryField2.summaryFunction = summFunc;
                      summaryRow.fields = [summaryField,summaryField1,summaryField2];
                      summaryRow.summaryPlacement = "group";
                      summaryRow.summaryObjectFunction = summObjFunc;
                      var grouping:Grouping = new Grouping();
                      var groupingField:GroupingField = new GroupingField("site");
                      var groupingField1:GroupingField = new GroupingField("merchant");
                      grouping.fields=[groupingField,groupingField1];
                      groupingField.summaries = [summaryRow];
                      groupingField1.summaries = [summaryRow];
                      groupingCollection.grouping = grouping;
                      groupingCollection.refresh();
                      return groupingCollection;
                 [Bindable]
                  private var dpFlat:ArrayCollection = new ArrayCollection([
                    {site:"BBVA", merchant:"TALLINK", Offer:"10% Off", newvisits:38865, redemptions:40000},
                    {site:"BBVA", merchant:"LIVEIT", Offer:"10% Off", newvisits:29885, redemptions:30000},
                    {site:"CartaSi", merchant:"Central California", Offer:"10% Off", newvisits:29134, redemptions:30000},
                    {site:"CartaSi", merchant:"Nevada", Offer:"10% Off", newvisits:52888, redemptions:45000},
                    {site:"BarclayCard", merchant:"Northern California", Offer:"10% Off", newvisits:38805, redemptions:40000},
                    {site:"BarclayCard", merchant:"Northern California", Offer:"10% Off", newvisits:55498, redemptions:40000},
                    {site:"Nordea", merchant:"Southern California", Offer:"10% Off", newvisits:44985, redemptions:45000},
                    {site:"Nordea", merchant:"Southern California", Offer:"10% Off", newvisits:44913, redemptions:45000},
                  private function summFunc(cursor:IViewCursor, dataField:String,
                      operation:String):Number {
                      var conversionrate:Number = 0;
                      conversionrate +=  (cursor.current["redemptions"] / cursor.current["newvisits"]) * 100
                      trace (dataField)
                      trace (conversionrate);
                      return conversionrate;
                   private function summObjFunc():SummaryObject {
                      // Define the object containing the summary data.
                      var obj:SummaryObject = new SummaryObject();
                      // Add a field containing a value for the Territory_Rep column.
                      obj.conversionrate2 = "Alternating Reps";
                      return obj;
          </mx:Script>
          <mx:DataGrid id="test" dataProvider="{dpFlat}">
          </mx:DataGrid>
          <mx:AdvancedDataGrid id="myADG"  width="100%" height="100%"  dataProvider="{createGrouping(dpFlat)}">
              <mx:columns>
                  <mx:AdvancedDataGridColumn dataField="site"/>
                  <mx:AdvancedDataGridColumn dataField="offer"/>
                  <mx:AdvancedDataGridColumn dataField="newvisits"/>
                  <mx:AdvancedDataGridColumn dataField="redemptions"/>
                  <mx:AdvancedDataGridColumn dataField="conversionrate"/>
                  <mx:AdvancedDataGridColumn dataField="conversionrate2"/>
              </mx:columns>
         </mx:AdvancedDataGrid>
          <mx:Button label="Button" click="groupingCollection.refresh()"/>
      </mx:Application>
        • 1. Re: Using The Summary Function in ADG
          MrFork Level 1
          For those who are interested this is the corrected custom summary function -
                          var totalNewVisits:Number = 0
                          var totalNewRedemptions:Number = 0
                          var tmpVisits:Number = 0;
                          var tmpRedemptions:Number = 0;
                          while (!cursor.afterLast)
                              tmpVisits = cursor.current["newvisits"];
                              totalNewVisits += tmpVisits;
                              tmpRedemptions = cursor.current["redemptions"];
                              totalNewRedemptions += tmpRedemptions;
                              cursor.moveNext()
                          conversionrate =  (totalNewRedemptions / totalNewVisits) * 100
