1 Reply Latest reply on Mar 3, 2010 12:33 PM by RossRitchey
    Operation Aborted Error in IE
    Mr. Benrud Level 1
      Hello Everyone,
      I'm getting the following error when I add a .swf file to my web site. The error only happens in IE.
      Internet Explorer can not open the site http://charitystudentinvestmentproject.com
      Operation Aborted
      Screen shot of the error
      Any ideas why?
      Todd
        • 1. Re: Operation Aborted Error in IE
          RossRitchey Level 4
          When I open the page in IE I get a javascript error that stops the page from loading.  If you run down the source of this error, you should be able to fix the problem:
          Webpage error details
          User Agent: Mozilla/4.0 (compatible; MSIE 8.0; Windows NT 5.1; Trident/4.0; chromeframe; .NET CLR 1.1.4322; .NET CLR 2.0.50727; .NET CLR 3.0.04506.30; .NET CLR 3.0.04506.648; .NET CLR 3.0.4506.2152; .NET CLR 3.5.30729; MS-RTC LM 8)
          Timestamp: Wed, 3 Mar 2010 20:27:42 UTC
          Message: HTML Parsing Error: Unable to modify the parent container element before the child element is closed (KB927917)
          Line: 0
          Char: 0
          Code: 0
          URI: http://charitystudentinvestmentproject.com/
          It appears as though you are running into problems with the SWFObject embed script, because the script and the Div it writes into is inside of the same div. Try moving the script block outside of the 2 div closures that immediately follow it.
