0 Replies Latest reply on Mar 3, 2010 10:49 AM by venkatsyss
    Regarding Array and Result handler
    venkatsyss Level 1
      hi,
      My question is,  i have added the record in flex end with backend php.Through Httpservice  i have added the records successfully.In the http service i have using result  method.In that method i declare a array and result is stored in that array.
      Select the records is  displayed in the dataGrid.Ex only two records was displayed in the datagrid, suppose if have selected a particular record and i was deleted table however the error is displayed after deleted  why because single record is selected in the query and returned it.
      I have defined a array for the  selected records is assigning it will show the error string cannot be converted into array.
      I could n't know how to solve the problem.
      Thanks and Regards,
      venkat.R
