3 Replies Latest reply on Mar 9, 2010 11:43 AM by kglad
    AS 2: Using an XML object to retreive a static XML file
      I’m working on learning how to bring  XML info into Flash. Eventually I’m trying to pull a bunch of data about  Interstate 80 drug and cash stops for an interactive project to go with a big  centerpiece story for the newspaper I work for.
      I’ve been through a Lynda.com tutorial  three times now. I made a dataset, bound it to a datagrid and attached the datagrid to the xml file. When I run a trace, I can see in the output window that the XML is being pulled in. But I must be doing something wrong nothing is being displayed in the datagrid. It should bring in the first three items in the  code: ‘yr, date, and when’ into their categories in the  grid, but it's just blank.
      Here’s the code in flash:
      var myXML:XML = new  XML();
      myXML.ignoreWhite =  true;
      myXML.onLoad =  function(success) {
                   if(success) {
                               for (var x=0;x<this.firstChild.childNodes.length;x++)  {
                               var i80Node:XMLNode =  this.firstChild.childNodes[x];
        when:i80Node.attributes.when });
                  } else  {
                               //Throw error here
      Here's the XML data:
      <?xml version="1.0"?>
        <rec yr="2009" date="9.9.08" when="3:47 p.m." />
      If you have any ideas, it’d be much  appreciated, I have been trying to figure this out for hours.
      I'm new to this XML to Flash thing. Mostly what I do is just make buttons and animations, so thanks so much for any  help!
