1 Reply Latest reply on Sep 8, 2007 5:37 AM by zbob99
    FDS,Coldfusion and Flex?
    mark416 Level 1
      I am a little confuse.Do you have a example and let me know how FDS,Coldfusion and Flex works together.and if FDS only works with Java.
      Mark
        • 1. FDS,Coldfusion and Flex?
          zbob99 Level 1
          Flex, CF and FDS (LCDS) work great together. For example I setup a monitoring system using Flex to build the front end graphical displays (charts, graphs, etc) then used CF Flex messaging event gateway to connect (publish/subscribe) and then used CF to push monitoring data to the Flex/Flash display screens. Its very cool!! The real magic is the push capability which means you can use server logic to control if and when data is sent -- no more polling!!
