6 Replies Latest reply on Mar 4, 2010 4:04 PM by pauland
    Flex vs Flash 8 operation
    landogilator
      I have been using Flash Professional 8 for several years (largely actionscript) and wanting to upgrade to Flex.
      However, I have concerns about the size of the resulting .swf files with Flex.
      I tried an experiment. Using Flash 8, I made a simple movie with a single text box, published and the .swf = 28kbytes.
      Same thing with Flex except .swf = 280kbytes. I added a list component to both and Flash .swf = 52kb, Flex .swf = 400kb.
      So, I am puzzled. What is it about Flex that is causing the .swf to swell to approx. 8-10x the size of Flash 8?
      Are more of the "controls" contained in the .swf with Flex? I must admit that I am ignorant about the operation of the Flash player other than it
      interprets the byte code. And I realize that some optimization can be obtained with Flex but I do not think this is the fundamental issue.
      Can anyone educate me as to how Flex works from the runtime(player) perspective? And how it differs from Flash 8? Why am I seeing significantly
      larger .swf files?
        • 1. Re: Flex vs Flash 8 operation
          Gregory Lafrance Level 6
          Probably due to Flex framework classes and supporting classes. Shouldn't be a problem for typical users, who no doubt will have broadband or DSL.
          If this post answers your question or helps, please mark it as such.
          Greg Lafrance - Flex 2 and 3 ACE certified
          www.ChikaraDev.com
          Flex / AIR Development, Training, and Support Services
          • 2. Re: Flex vs Flash 8 operation
            landogilator Level 1
            Thanks Greg. It helps although I still would like to understand it a bit more.
            The bottom line is that the Flex Framework requires a larger file size to do what it does.
            My issue with a larger file is not so much the time it takes to download, but the memory consumption on
            the server side. I am using an embedded application server where every byte counts in the file system. No Gbyte harddrives available.
            • 3. Re: Flex vs Flash 8 operation
              If you are creating small apps, I would stay with Flash. If you are creating more substantial webapps, then the increased file size is somewhat unavoidable, unless you go with AJAX, but mid to long-term that would not be as good a choice as Flex.
              www.ChikaraDev.com
              • 4. Re: Flex vs Flash 8 operation
                pauland Level 4
                Even if the Flex libraries are too heavy for your situation, you could still use AS3 and avoid the Flex framework altogether (or indeed just carry on as you are).
                • 5. Re: Flex vs Flash 8 operation
                  Which leads to another question, pauland...perhaps Flash CS4/AS3 is a better fit? I really had my heart set on the charting features.
                  Will have to download the trial CS4 and give it a try. Thanks.
                  • 6. Re: Flex vs Flash 8 operation
                    pauland Level 4
                    Just bear in mind that CS5 is due to appear reasonably soon, so that may be something to remember. A  lot of people on the forums use Flex for Actionscript development and other IDEs besides CS4.
