0 Replies Latest reply on Mar 3, 2010 10:02 PM by Deeptika Gottipati
    [svn:fx-4.x] 14570: Using method in AutomationManager to trace messages
    Deeptika Gottipati Adobe Employee
      Revision: 14570
      Revision: 14570
      Author:   deeptika@adobe.com
      Date:     2010-03-03 22:02:16 -0800 (Wed, 03 Mar 2010)
      Log Message:
      QE notes: All trace messages in delegates that showed up while debugging should show class and method name in addition to actual message
      Doc notes:
      Bugs:
      Reviewer:
      Tests run: checkintests
      Is noteworthy for integration: No
      Modified Paths:
          flex/sdk/branches/4.x/frameworks/projects/automation/src/mx/automation/codec/AutomationOb jectPropertyCodec.as
          flex/sdk/branches/4.x/frameworks/projects/automation/src/mx/automation/codec/RendererProp ertyCodec.as
          flex/sdk/branches/4.x/frameworks/projects/automation/src/mx/automation/delegates/TextFiel dAutomationHelper.as
          flex/sdk/branches/4.x/frameworks/projects/automation/src/mx/automation/delegates/controls /SWFLoaderAutomationImpl.as
          flex/sdk/branches/4.x/frameworks/projects/automation/src/mx/automation/delegates/core/UIC omponentAutomationImpl.as
          flex/sdk/branches/4.x/frameworks/projects/automation/src/mx/automation/delegates/core/UIT extFieldAutomationImpl.as
          flex/sdk/branches/4.x/frameworks/projects/automation/src/mx/automation/tabularData/OLAPDa taGridTabularData.as
          flex/sdk/branches/4.x/frameworks/projects/automation_air/src/mx/automation/delegates/cont rols/FlexNativeMenuAutomationImpl.as
          flex/sdk/branches/4.x/frameworks/projects/automation_dmv/src/mx/automation/delegates/adva ncedDataGrid/AdvancedDataGridAutomationImpl.as
          flex/sdk/branches/4.x/frameworks/projects/automation_spark/src/mx/automation/delegates/co re/UIFTETextFieldAutomationImpl.as
          flex/sdk/branches/4.x/frameworks/projects/automation_spark/src/spark/automation/delegates /components/supportClasses/SparkDropDownListBaseAutomationImpl.as
          flex/sdk/branches/4.x/frameworks/projects/automation_spark/src/spark/automation/delegates /components/supportClasses/SparkListBaseAutomationImpl.as
          flex/sdk/branches/4.x/frameworks/projects/automation_spark/src/spark/automation/tabularDa ta/SparkListBaseTabularData.as
