13 Replies Latest reply on Mar 4, 2010 1:19 PM by Flex harUI
    Loading bitmapdata from external image?
    Pete Heinz
      Hi everyone,
      I'm trying to retrieve the bitmapdata from an external image. In order to test my code, I convert the bitmapdata data a bitmap and I add it to the stage. Unfortunately I get a TypeError: Error #1034: Type Coercion failed: cannot convert flash.display::Bitmap@6b147e1 to mx.core.IUIComponent.
      Do you see why this error occurs?
      My code:
      import flash.display.BitmapData;
      import flash.display.Bitmap;
      private var bitmapData:BitmapData;
      private function init():void
           var loader:Loader = new Loader();
           loader.contentLoaderInfo.addEventListener(Event.COMPLETE, onComplete);
           loader.load(new URLRequest("Beach.jpg"));
           var myImage:Bitmap = new Bitmap(bitmapData);
           addChild(myImage);
      private function onComplete (event:Event):void
            bitmapData = Bitmap(LoaderInfo(event.target).content).bitmapData;
      Thanks in advance
        • 1. Re: Loading bitmapdata from external image?
          jciglesias@uci.cu
          try to add the bitmap firt to a sprite object  as a container and then this to the stage
          let me know if that works
            //adding the image to a container (  sprite  )
              var container:Sprite = new Sprite();
              container.addChild( myImage );
             // then add the container to the stage
               addChild(container);
          • 2. Re: Loading bitmapdata from external image?
            Pete Heinz Level 1
            It doesn't give any errors now. The image is still not displayed though.
            • 3. Re: Loading bitmapdata from external image?
              jciglesias@uci.cu Level 1
              sorry I miss one thing
              you need to show your image when the event onComplete is done
              if dosen't work now check your URLRequest
                   // adding the container to a stage
                   addChild(  container );
              • 4. Re: Loading bitmapdata from external image?
                Karl_Sigiscar_1971 Level 3
                Or you can simply use the Image component to load the picture, since it extends SWFLoader which extends UIComponent.
                You can set the source property to a given URL and wait for the complete event.
                • 5. Re: Loading bitmapdata from external image?
                  Pete Heinz Level 1
                  It still doesn't display the image. The URL is correct.
                  This is my code:
                  private var myImage:Bitmap;
                       myImage = new Bitmap(bitmapData);
                  • 6. Re: Loading bitmapdata from external image?
                    you need to put this lines into the event onComplete, because is when the external image is complete loaded
                    until that moment there's no image to show
                    • 7. Re: Loading bitmapdata from external image?
                      Pete Heinz Level 1
                      I moved that code to the onComplete-handler but the image is still not displayed.
                      My code:
                      • 8. Re: Loading bitmapdata from external image?
                        sorry man,, your right,, it doesn't work, but know it does I just proved
                             loader.load(new URLRequest("C:\\Users\\Administrador\\Documents\\Flex Builder 3\\prueba\\src\\foto.jpg"));
                             myImage = Bitmap(LoaderInfo(event.target).content);
                              this.rawChildren.addChild(container);
                        • 9. Re: Loading bitmapdata from external image?
                          Pete Heinz Level 1
                          I want to fill the bitmapData-variable with the data of the image. Do you know how to do that?
                          • 10. Re: Loading bitmapdata from external image?
                            BitMapData = myImage.bitmapdata;
                            • 11. Re: Loading bitmapdata from external image?
                              Pete Heinz Level 1
                              Now I want to convert the bitmapdata to a bitmap and display it. I get this error:
                              TypeError: Error #1034: Type Coercion failed: cannot convert flash.display::BitmapData@727c629 to flash.display.Bitmap.
                              Can you explain how to convert bitmapdata to bitmap and display it properly?
                              My code:
                                   loader.load(new URLRequest("Strand.jpg"));
                                   bitmapData = new BitmapData(320,240);
                                   bitmapData = myImage.bitmapData;
                                   container.addChild( Bitmap(bitmapData) );
                              • 12. Re: Loading bitmapdata from external image?
                                you can't do that,, those classes work together,,
                                bitmap  has the propertys of the image and the other data of the image like pixel and those thing,,
                                when you wanna show an image you just  show the bitmap and only that,, that's why you cant do that convertion
                                • 13. Re: Loading bitmapdata from external image?
                                  Flex harUI Adobe Employee
