1 Reply Latest reply on May 12, 2015 9:25 PM by robertm73883890
    How to extract PDF files from portfolio?
    kosovec Level 1
      hi,
      help needed.
      I´d like to ask, how to extract PDFs from portfolio. I have to create portfolio, bcs i am creating PDFs with XFA data.
      In first step i made PDF portfolio from PDF files, then user should fill it up. And then i need get PDF files, because i need extract data from them. For creation portfolio i use DDX :
      <DDX xmlns="http://ns.adobe.com/DDX/1.0/">
        <PDF result="Acrobat 9 Portfolio">
          <Portfolio>
            <Navigator source="AdobeRevolve.nav"/>
            <Schema>
              <Field name="Character" type="Filename"/>
              <Field name="Location" type="Text"/>
            </Schema>
          </Portfolio>
          <PackageFiles>
            <PDF source="Swami.pdf"/>
            <PDF source="Sherlock.pdf"/>
            <FieldData name="Location">London</FieldData>
          </PackageFiles>
        </PDF>
      </DDX>
      I know extract data from one PDF document, but i need to get PDFs from portfolio. Can you HELP? Thanks.....
        • 1. Re: How to extract PDF files from portfolio?
          robertm73883890 Level 1
          Hello,
          I am not sure if this will help. However, I can export data from a portfolio to excel by doing the following:
          I extract all the pages from the portfolio into single PDFs
          I open the first PDF
          Click on Tools
          Under Forms, I select More From Options
          I select Merge Data Files into Spreadsheet
          The pop-up box allows you to add all of the additional files that you made from the portfolio
          Click on them then click Export
          It will ask for a file name and place to save it.
