1 Reply Latest reply on Mar 5, 2010 1:07 PM by danielbala
    scope issue... launching applicaion
    danielbala
      I am having trouble calling launchApplication().
      I was able to narrow my problem, I think it is a scope issue, maybe you can help ( I am a .NET developer, not so much AS3)
      This code snippet is from the AIRBadge.as provided in the AIR SDK
      This code works:
      private var _appURL: String;
      private var _appName: String;
      private var _airVersion: String;
      private var appID:String = “com.dbala.ihpapp.app”;
      private var pubID:String = “”; //
      private var launch_args:Array = ["launchFromBrowser"];
      private function onButtonClicked(e:Event):void {
      _air.installApplication( _appURL, _airVersion );
      This code does NOT work:
      _air.getApplicationVersion(appID, pubID, versionDetectCallback);
      private function versionDetectCallback(version:String):void{
      if (version == null)
      //this message displays
      root.statusMessage.htmlText = "blablabla installing";
      //this function DOES NOT execute
      root.statusMessage.htmlText = "blablabla after installing";
      else
      root.statusMessage.htmlText = "Launching Application..";
      _air.launchApplication(appID, pubID, launch_args);
      I need help because it is difficult to determine if _air is accesible in versionDetectCallback
      when I trace _air, I see [object AIR] which doesn't really help me.
