5 Replies Latest reply on Mar 1, 2011 2:16 AM by Jimmytech
    Error when opening a pdf file
    mgregg2970 Level 1
      I have QTP 10.0 and Adobe reader 9.3 installed on my machine. The machine I am using is a VMware device.
      I have downloaded and installed the PDF Test Toolkit and the Adobe SDK.
      For QTP I have the ActiveX, Web and Adobe add ins loaded.
      I do not have Acrobat loaded.
      For my first script all I wanted to do was open an existing PDF. I used the code displayed below.
      ___________________________________
      Option Explicit
      Dim gApp
      Dim gPDDoc
      '###  Create objects required for the test
      Set gApp = CreateObject("AcroExch.App")
      Set gPDDoc = CreateObject("AcroExch.PDDoc")
      '###  Open a PDF Document
      gPDDoc.Open ("C:\TestData\PerfOnVMware")
      '###  Kill all created objects
      Set gPDDoc = Nothing
      Set gApp = Nothing
      __________________________________________
      For both Set statements (in italics) I am getting the following message
      "ActiveX Component Can't Create Object "AcroExch.App"
      Also, as to the instructions. I read the instructions to mean that you need the Adobe Reader OR Adobe Acrobat. However in some of the research I have been doing on other boards many of the solutions indicate that Acrobat is required. Can some one take a moment and clarify what I will need installed on each machine in order to create and execute scripts.
      Any thoughts would be helpful
      Mike
