2 Replies Latest reply on Sep 7, 2007 8:23 AM by asm0d
    Presenter "Slide Properties"
    Level 7
      I'd like to NOT have slides automatically advance. This seems like a
      reasonable option, but the way I configure it in Presenter is a little
      bumpy.
      Presenter > Slide Properties >
      Select all slides, EDIT, check the "Advance by User" box.
      Is there a way to make this the default?
      KC
        • 1. Re: Presenter "Slide Properties"
          Level 7
          By the way...
          Presenter > Presentation Settings > Pause After Each Animation
          Only prevents progressing to the next slide if the current slide has an
          animation.
          KC
          • 2. Re: Presenter "Slide Properties"
            asm0d Level 1
            Nope. :) You could write a quick script to modify the underlying XML files, but why bother when it only takes a few seconds to modify them by hand with the Presenter interface?
            However... you could make up a blank presentation with 20 - 30 slides to serve as a template. If you set the Presenter options for your template, then use a copy of it for all subsequent training, it will retain all the "default" settings you've made. The same thing goes for using the "duplicate slide" command in PowerPoint; if you duplicate a slide with "pause after animation" set, the duplicate has the same setting.
