0 Replies Latest reply on Mar 4, 2010 2:57 PM by GabrielGelsy
    Accessing data from a dynamic text field id
    GabrielGelsy
      Hi!
      I made a text field with a dynamic id. The source code of the dynamic text field is here:
      <input name="text_dynamic<?php echo $row_text['id']; ?>" type="text" id=dynamicElement<?php echo $row_text['id']; ?> value="<?php echo $var; ?>"/>
      The problem is that I don't know how to acces to the data of the text field. I have tried many times but the only that I get are more and more errors.
      The form that contains the text field send the data by post method.
      If I have this php sentence: "<?php echo $_POST['field'] ?>", what I should put instead 'field' if I want to show the content of the text field?
      Notes:
      -I used Dreamweaver CS4
      -The form that contains the text field send the data by post method
      -I have a repeating region that contains the form and show a text field for each element of the repeating region
      -I want to use the "update record" function with the text fields
      -I have the problem with the following sentence:
      GetSQLValueString($_POST['field'], "int"),
      (where 'field' is the id of the text field)
