4 Replies Latest reply on Apr 12, 2010 3:32 AM by BKBK
    Webservice not accessible using cfinvoke,but emptystring in errordetail,filecontent using cfhttp
    sivakarthikeyan Level 1
      Hello,
      When I am invoking the webservice with the following code. I am getting the following error.
      Unable to  parse WSDL as an XML document.
      Parsing   error: Fatal Error:  URI=null Line=168: The element type   "link" must be terminated by the matching  end-tag   "".
      It is recommended that you use a web browser to retrieve  and examine   the requested WSDL document to ensure it is correct.
      Code that I have used is :
      <CFINVOKE component="userinfo" METHOD="GetuserInfo" RETURNVARIABLE="result_info" >
           <cfinvokeargument name="EMP" value="123456"/>
      </cfinvoke>
      <cfdump var="#result_info#">
      <CFINVOKE webservice="http://www.test.com/userinformation.cfc?wsdl" METHOD="GetVehInfo" RETURNVARIABLE="result_info" >
      </cfinvoke>
      We were able to call the component and get the output. While changing the same component as webservice by adding access="remote", we are able to navigate to the WSDL page. But, when we try to call the same, we receive the error.
      Then , it worked while accessing a webservice using cfhttp .
      We are facing another issue while accessing a java webservice using coldfusion (i.e., cfhttp)
      Coldfusion Server is in Windows Environment (i.e., consumer )
      Java /J2eee code is hosted IBM application server in Unix Envionment (i..e., producer /service provider)
      We are accessing the webservice url using the colfusion cfhttp method as below  with the WSL credential and soap request.
      <cfhttp url="<<Webservicepath>>" method="post"  >
           <cfhttpparam type="header" name="content-type" value="text/xml">
           <cfhttpparam type="header" name="SOAPAction" value="<<SOAPACTIONPATH>>">
           <cfhttpparam type="header" name="content-length" value="#len(myxmlsoaprequest)#">
           <cfhttpparam type="header" name="charset" value="utf-8">
           <cfhttpparam type="cookie" name="WSL-credential" value="<<Cookie>>">
              <cfhttpparam type="xml" name="message" value="#myxmlsoaprequest#">
          </cfhttp>
      We get cfhttp.filecontent as empty and cfhttp.errordetail as  empty as like below.
      Charset
      ISO-8859-1
      ErrorDetail
      [empty string]
      Filecontent
      [empty string]
      Header
      HTTP/1.1   200 OK Connection: close Expires: Thu, 01 Jan 1970 00:00:00 GMT   Content-Language: en-US Date: Thu, 04 Mar 2010 12:32:16 GMT Server:   IBM_HTTP_Server/6.1.0.25 Apache/2.0.47 Content-Length: 0 Pragma: no-cache   Cache-Control: no-cache Content-Type: text/html; charset=ISO-8859-1
      Mimetype
      text/html
      Responseheader
      struct
      Cache-Control
      no-cache
      Connection
      close
      Content-Language
      en-US
      Content-Length
      0
      Content-Type
      Date
      Expires
      Explanation
      OK
      Http_Version
      HTTP/1.1
      Pragma
      no-cache
      Server
      Status_Code
      200
      Statuscode
      200   OK
      Text
      YES
      while checking further , we found that we have received the below error log information in the service provider server error log (UNiX).
      DCSV1036W: DCS Stack DefaultCoreGroup at Member : An unusual connectivity state occured with member
      details: alarm(): Closing the connection because members did not manage to connect.
      Can you please advise
