2 Replies Latest reply on Apr 14, 2010 6:20 AM by levancho
    FileReference.load() crashes FireFox
    haibin_sh
      I'm using FileReference.load() to upload files to server. Usually the file size is about 50M. It _is_ working fine most of the time. But sometimes it crashes FireFox.
      I tried to catch the exception, but I did not see any logging when it crashed.
                      try
                          refUploadFile.load();
                      catch(error:Error)
                          if (error is IllegalOperationError)
                              trace("error is IllegalOperationError");
                          else if (error is MemoryError)
                              trace("error is MemoryError");
                          throw error;
      I'm using Windows XP, FireFox 3.6, Flash Player Debug version 10.0.32.18, Flex Builder 3.0, Flex SDK 3.4
      I need to get it fixed. Any idea what I shall do.
      Regards,
      Haibin
        • 1. Re: FileReference.load() crashes FireFox
          haibin_sh Level 1
          I write a very simple swf with the following code and test it with a selection of 32 files (each file is about 60M). It crashes every time.
          var fileRefList:FileReferenceList = new FileReferenceList();
          fileRefList.addEventListener(Event.SELECT, selectHandler);
          fileRefList.browse();
          function selectHandler(event:Event):void
              var file:FileReference;
              var files:FileReferenceList = FileReferenceList(event.target);
              var selectedFileArray:Array = files.fileList;
              for (var i:uint = 0; i < selectedFileArray.length; i++)
                  file = FileReference(selectedFileArray[i]);
                  file.addEventListener(Event.COMPLETE, completeHandler);
                  try
                      file.load();
                  catch (error:Error)
                      trace("Unable to upload files.");
          function completeHandler(event:Event):void
              trace("uploaded");
          • 2. Re: FileReference.load() crashes FireFox
            levancho Level 3
            IMHIO, you are pushing serious  limits there, and FP does not seem to have anough time to GC so it reaches way beyond  the limits of allocated Memory
            32x60 = thats almost 2 GB
            have you opened a task manager and monitor firefox proccess while you are doung upload, I bet it skyrockets in memory consuptiona and then dies.
