2 Replies Latest reply on Mar 10, 2010 6:43 AM by Ghintzen
    Bug??
    Ghintzen
      Everyone a Answer?
      Every time when I print a PDF as  A3, I must first open and close extends menu (I make no modifikation). Otherwise it print A4 size on A3 sheets
      Thanks an best regard
      Guido
        • 1. Re: Bug??
          sweafa_
          I experienced the same problem.
          As i only need to print a PDF as A3, i got this solution:
          Go to the Preferences of your Adobe PDF Printer, via Control Panel -> Printers & Faxes.
          There at the General tab you click on the "Printer Settings" Button.
          At the Dialog at the tab Adobe PDF Settings you choose A3. Click OK.
          At the Preferences-Dialog you click on the tab Device Settings. There you also choose at OnlyOne: A3.
          I think you now will have the problem all again, but contrary. You will have to print twice that you get A4 or any other size than A3...
          It behaves like a bug, yes.
          • 2. Re: Bug??
            Ghintzen Level 1
            THX.
            Best Regards
            Guido
