7 Replies Latest reply on Mar 9, 2010 7:06 AM by Shonkyin
    [AS] doScript with arguments
    r_olsen Level 1
      I'm trying to execute a js script through applescript but can't get the syntax right.
      I'd like to parse var myFolder to do script. Any hints?
      // execute js file
      set myFile to choose file with prompt "Choose a script"
      set myFolder to choose folder with prompt "Choose a folder"
      display dialog "myFolder is " & myFolder
      tell application "Finder"
           set myFileExt to name extension of myFile
      end tell
      tell application "InDesignServer"
           if myFileExt is "jsx" then
                      --call this method with argument myFolder?
                do script myFile language javascript
           else
                     do script myFile language applescript language
           end if
      end tell
      // js
      // print arguments
      i = 0;
      while (i < withArguments.length) {
           app.consoleout(withArguments[i]);
           i++;
        • 1. Re: [AS] doScript with arguments
          Shonkyin Level 3
          Here below is example for doscript with arguments. Hope it will help you.
          --DoScriptReturnValues.applescript
          --An InDesign CS4 AppleScript
          --Shows how to get values back from a script run using
          --the do script command.
          main()
          on main()
               mySetup()
               mySnippet()
               myTeardown()
          end main
          on mySetup()
          end mySetup
          on mySnippet()
               tell application "Adobe InDesign CS4"
                    --<fragment>
                    set nameA to "ScriptArgumentA"
                    set nameB to "ScriptArgumentB"
                    set nAc to nameA & ": "
                    set nBc to nameB & ": "
                    --Create a string to be run as an AppleScript.
                    set p1 to "tell application \"Adobe InDesign CS4\"" & return
                    set p2 to "tell script args" & return
                    set p3 to "set value name \"ScriptArgumentA\" value "
                    set p4 to "\"This is the first AppleScript script argument value.\""
                    set p5 to "set value name \"ScriptArgumentB\" value "
                    set p6 to "\"This is the second AppleScript script argument value.\""
                    set p7 to "end tell" & return
                    set p8 to "end tell"
                    set myAppleScript to p1 & p2 & p3 & p4 & return & p5 & p6 & return & p7 & p8
                    --Run the AppleScript string.
                    do script myAppleScript language applescript language
                    --Retrieve the script argument values set by the script.
                    tell script args
                         set myScriptArgumentA to get value name nameA
                         set myScriptArgumentB to get value name nameB
                    end tell
                    --Display the script argument values in a dialog box.
                    display dialog nAc & myScriptArgumentA & return & nBc & myScriptArgumentB
                    --Create a string to be run as a JavaScript.
                    set p1 to "app.scriptArgs.setValue(\"ScriptArgumentA\", "
                    set p2 to "\"This is the first JavaScript script argument value.\");" & return
                    set p3 to "app.scriptArgs.setValue(\"ScriptArgumentB\", "
                    set p4 to "\"This is the second JavaScript script argument value.\");" & return
                    set myJavaScript to p1 & p2 & p3 & p4
                    --Run the JavaScript string.
                    do script myJavaScript language javascript
                    tell script args
                    end tell
                    --</fragment>
               end tell
          end mySnippet
          on myTeardown()
          end myTeardown
          Shonky
          • 2. Re: [AS] doScript with arguments
            r_olsen Level 1
            Was this taken from the InDesign sample scripts? In that case I'm sorry for the ignorance
            Will give it another go - thanks!
            Rasmus
            • 3. Re: [AS] doScript with arguments
              r_olsen Level 1
              Hi again,
              This works:
                   set line1 to "var s = \"some string\";" & return
                   set line2 to "alert(s);"
              set myJavaScript to line1 & line2
              But this doesn't:
                   set line1 to "scriptArgs.setValue(\"arg1\",\"myValue\");" & return
                   set line2 to "var value = scriptArgs.getValue(\"arg1\");" & return
                   set line3 to "alert(value);"
              set myJavaScript to line1 & line2 & line3
              A little help?
              Rasmus
              • 4. Re: [AS] doScript with arguments
                Shonkyin Level 3
                Try below one
                     set line1 to "app.scriptArgs.setValue(\"arg1\",\"myValue\");" & return
                     set line2 to "var value = app.scriptArgs.getValue(\"arg1\");" & return
                end tell
                Shonky
                • 5. Re: [AS] doScript with arguments
                  r_olsen Level 1
                  That did it - thanks
                  • 6. Re: [AS] doScript with arguments
                    Harbs. Level 6
                    Shonky,
                    When you post other people's scripts, please write a note that you are doing such.
                    Harbs
                    • 7. Re: [AS] doScript with arguments
                      Shonkyin Level 3
                      I'll do this Harbs.
                      Shonky
