I'm sure this is obvious to a seasoned person but I'm a newbie (just working with Forms for 1 week).
In the snapshot below I'm trying when I hit the Add button I'd like the two rows below the header in the table to replicate themselves below in the table.
Eventually there will be many rows to replicate. The problem is that I can't find a way to group these and then reference them by the javascript in the "add button" so that they replicate together.
any help/pointers etc. are much appreciated.
Thx
Views
Total Likes
You can only add 1 row at a time .....so if you want to add three rows then you would have to run the command three times.
Make sense?
Paul
Views
Total Likes
That explains why I couldn't figure out how to do it.
How about ..can I instantiate an entire table over and over at the press of
the add button? I've tried but I suspect I'm just not referencing the object
right or something?
Thanks for your help
George
Views
Total Likes
If the form is setup correctly (the container that holds the table is set to flowed) then it should be possible.
Paul
Views
Total Likes
Thanks again Paul. I believe the container is set to "flowed" but since I'm
new with forms and Livecycle (although I do know Java) I think I might not
be instantiating the table properly.
for eg. see attachment. I use--> details.addInstance(1)
but it doesn't do anything.
I'm trying to replicate the entire table when I hit the "add item" button
any ideas.
George
Views
Total Likes
sorry missing attachment
Views
Total Likes
You can't add attachments here at the moment .....you will have to send it to me via email (LiveCycle8@gmail.com).
Paul
Views
Total Likes
What was the outcome of this? I am trying to create a form by having a whole table added at the click of a button but can't make it work. This sounds similar but no solution is made available and I can't find anything else on the forums.
Greig
Views
Total Likes
Views
Likes
Views
Likes
