0 Replies Latest reply on Mar 5, 2010 12:06 PM by Jason Szeto
    [svn:fx-trunk] 14608: Merge revision 14607 from 4.x to trunk
    Jason Szeto Level 3
      Revision: 14608
      Revision: 14608
      Author:   jszeto@adobe.com
      Date:     2010-03-05 12:06:31 -0800 (Fri, 05 Mar 2010)
      Log Message:
      http://bugs.adobe.com/jira/browse/SDK-25723 - The gripper in a Spark Window (with Flex chrome) should be flipped when layoutDirection="rtl"
      Cleared out the layoutDirection property for the BitmapImage containing the gripper skin
      http://bugs.adobe.com/jira/browse/SDK-25698 - Popup doesn't inherit rtl layoutDierction from its parent PopupButton
      Fixed PopupButton, ColorPicker and DateField to open the dropDown from right to left. For PopUpButton and ColorPicker, this means that the right edge of the dropdown should align with the right edge of the anchor button. For DateField, this means the right edge of the dropdown should align with the right edge of the calendar icon.
      In ColorPicker, I had to validate the dropDown in order to get its width. ComboBox, PopupButton and DateField create their dropdowns early or perform the validation when it is first opened.
      QE notes: n/a
      Doc notes: n/a
      Bugs: SDK-25723, SDK-25698
      Reviewer: Kevin
      Tests run: checkintests, ColorPicker, PopUpButton, DateField
      Is noteworthy for integration: no
      Ticket Links:
      Modified Paths:
          flex/sdk/trunk/frameworks/projects/airspark/src/spark/skins/spark/windowChrome/GripperSki n.mxml
          flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/ColorPicker.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/DateField.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/PopUpButton.as
      Property Changed:
          flex/sdk/trunk/
