11 Replies Latest reply on Mar 23, 2010 7:24 AM by NOCK2k8
    If...and statements for Countdown Timers
    NOCK2k8 Level 1
      Hey guys,
      I currently have this code:
      on exitFrame me
        if sprite("man").intersects(sprite("finish")) then
          go to "EndScreenLevel1Win"
        else
          go to frame "Level1"
        end if
      end
      I want to change it so that it's more like:
      on exitFrame me
        if sprite("man").intersects(sprite("finish")) AND CountdownTimer =>0 then
        if sprite("man").intersects(sprite("finish")) AND CountdownTimer == 0 then
           go to "EndScreenLevel1Lose"
        else
        end if
      end
      How would I go about doing this?
      I know what I have written isn't quite right, somebody will probably know straight away what I need to do.
      Any help greatly appreciated.
      Thanks in advance,
      James
        • 1. Re: If...and statements for Countdown Timers
          Chunick Level 3
          I would write it like this:
            if (sprite("man").intersects(sprite("finish"))) AND (CountdownTimer > 0) then
              put "EndScreenLevel1Win"
            else if (sprite("man").intersects(sprite("finish"))) AND (CountdownTimer = 0) then
              put "EndScreenLevel1Lose"
            else
              put "Level1"
            end if
          • 2. Re: If...and statements for Countdown Timers
            NOCK2k8 Level 1
            Thanks for your speedy reply.  Unfortunately I know get an error stating:
            Script error: variable used before assigned a value
              if (sprite("man").intersects(sprite("finish"))) AND (CountdownTimer >? 0) then
            How should I define it?
            Thanks in advance!
            • 3. Re: If...and statements for Countdown Timers
              NOCK2k8 Level 1
              By changing the code slightly to this:
              on exitFrame me
                if sprite("man").intersects(sprite("finish")) AND ("CountdownTimer" > "0:00") then
                else if (sprite("man").intersects(sprite("finish"))) AND ("CountdownTimer" < "0:00") then
                else
                end if
              end
              I get the result of it moving to the frame labelled 'EndScreenLevel1Win' but, it never directs to 'EndScreenLevel1Lose'.  Any ideas why this might be?  So close, yet...so far!
              • 4. Re: If...and statements for Countdown Timers
                Mike Blaustein Level 4
                Do you have a countdown timer?  If so, what is it called?  Is it a variable?  or a text member?
                or a sprite?  etc.  We really can't tell you how to do what you are asking without knowing how your stuff is set up.
                • 5. Re: If...and statements for Countdown Timers
                  NOCK2k8 Level 1
                  Right, I'm still trying to get my head around all of this terminology, but I think that:
                  It is text with code added to it, when I click it on stage it says in the property inspector:
                  Sprite 5: Text
                  CountdownTimerText
                  Internal
                  I have then put CountdownTimer into the 'Name' field.
                  Should my code be saying WHEN CountdownTimerText > 0:00 instead of CountdownTimer do you think?
                  Sorry to be a pain, I hope that I explained that okay?
                  Thanks for your help.
                  • 6. Re: If...and statements for Countdown Timers
                    Chunick Level 3
                    I don't know why you are now getting an error... I simply took your code and rewrote it so that the logic would work. Nothing more.
                    btw, 0:00 is not a valid value for a variable. If it was a string, eg. "0:00" then it would be... however, you then couldn't reliably compare a string as you would a numerical value using the greater than or less than operators.
                    As well, CountdownTimerText in the Property Inspector would be the name of the member, not a variable and not the name of the sprite.You need to pick up a book on Director or work through some online tutorials such as the ones here: http://www.deansdirectortutorials.com
                    • 7. Re: If...and statements for Countdown Timers
                      NOCK2k8 Level 1
                      Right...
                      I've looked through the tutorials, and still don't get it.
                      I understand why you cannnot compare 0 to a string, and I understand that my timer is a sprite not a variable in the if...then code that I'm trying to use to make the decision.
                      But I still have no idea how to make that code work. Unless, I have to build a countdown timer in that code too, so I effectively have two timers: 1 that the user sees and the other that lingo uses to make the comparison?
                      Any help would be greatly appreciated.  Thanks in advance.
                      • 8. Re: If...and statements for Countdown Timers
                        Chunick Level 3
                        Ok, so you've really never written code before. Maybe you could explain what you're trying to do and I can write some code examples with comments to illustrate.
                        • 9. Re: If...and statements for Countdown Timers
                          NOCK2k8 Level 1
                          I've written code, just not Lingo code.
                          I have my game screen which involves a movie sprite man getting to the finish.
                          I also have a sprite that counts down from 5:00 to 0:00 for the user to see.
                          I want to set it up so that if the user successfully navigates from the start to finish that they see a 'Congratulations you win screen', and if the timer runs down to 0:00 before they get there a 'Unlucky, you failed' screen.
                          I thought that there would be a million tutorials on the 'net for this but can't find any.
                          I'm thinking that in the code for my Level1 screen I need to set up some global variables such as:
                          global CountdownTimer, TimerStart, TimerEnd
                          But that is about all I have come up with :S
                          Any help would be great.  Thanks in advance.
                          • 10. Re: If...and statements for Countdown Timers
                            Sean_Wilson Adobe Community Professional
                            So you have code on this sprite that drives the timer. Did you write it, or did it come from the Library Palette or elsewhere?
                            • 11. Re: If...and statements for Countdown Timers
                              NOCK2k8 Level 1
                              I've answered my own question.
                              All I need to do was modify the code that I had added to the timer sprite.  I've pasted it below:
                              -- behaviour script attched to a text sprite
                              on beginSprite me
                                sprite(me.spriteNum).member.text = "5:00"
                                startTimer()
                              end beginSprite
                              on enterFrame me
                                tSecElapsed = (the timer)/60
                                if tSecElapsed < 300 then
                                  tTime = 300 - tSecElapsed
                                  tSec = tTime mod 60
                                  if tSec < 10 then
                                    tSec = "0" & tSec
                                  end if
                                  tMin = tTime/60
                                  sprite(me.spriteNum).member.text = tMin & ":" & tSec
                                else
                                  sprite(me.spriteNum).member.text = "0:00"
                                end if
                              end enterFrame
                              3 lines up from the bottom where is says   go to "EndScreenLevel1Lose" is all I need to add in so that when the timer hits 0:00 it moves to the "EndScreenLevel1Lose" screen.
                              Chuffed to say the least.
                              Big thanks to all those that tried to help.
