2 Replies Latest reply on Mar 9, 2010 2:09 AM by huray
    Interval to remove MC
    huray Level 1
      I have a movie clip which on enterframe duplicates movie clips. I want to set an interval to stop it from duplicating for 3 seconds then start duplicating again.
      I have tried the following:
      red.onEnterframe =function () { timer=setInterval (unloadMovie(hat,3000),clearInterval(timer); };
      I get not effect,  but when I delete clearInterval(timer), it stops duplicating and swf and Flash are force to close.
      Need help for this.
        • 1. Re: Interval to remove MC
          You can build a conditional into your enterframe function that checks a value to determine if it should process whatever it processes or not.  Have some mechanism set that variable to false and call a setTimeout function that waits 3 seconds before calling a function that sets that variablew back to true.
          var createMCs = true;
               if(createMCs){
                    // whatever your enterframe does
          // ??? Missing link goes here - what sets the createMCs value to false?
          var delayProcessing:Number = setTimeout(delayFunction, 3000);
          function my_delayedFunction (arg1) {
                createMCs = true;
          What is missing in your description of this scheme is the mechanism that triggers the 3 seconds of no enterframe output.  Your 3 seconds of non-productivity has to start at some point, and that starting point is what is missing.  If the intention is to have it trigger every 3 seconds, then using setInterval would be more appropriate and would only need to involve toggling that true/false variable in each cycle (createMCs = !createMCs).
          • 2. Re: Interval to remove MC
            huray Level 1
            The following is my script:
            var timer;
            red.onEnterFrame=function() {timer=setInterval(unloadMovie(hat,3000);clearInterval(timer);
                _root.flower= 1;
                _root.i += 1;
                duplicateMovieClip(_root.hat, "hat"+_root.getNextHighestDepth(),
                _root.getNextHighestDepth());
            Attach to movie clip "basket",
            onClipEvent (load) {
                this._visible = 0;
                if (_root.flower == 1) {
                    this._x = _root.basket._x;
                    this._y = _root.basket._y;
            onClipEvent (enterFrame) {
                if (this != _level0.bullet) {
                        this._y -= 5;
                        this._visible = 1;
                    if (this._y<0) {
                        this.removeMovieClip();
            what I want is hat is duplicating from basket for 3 seconds, stop, then duplicate again for another 3 seconds.
            I did intergrate your script but hat is not duplicating. Hoping your amendment.
