4 Replies Latest reply on Mar 15, 2010 6:52 AM by -Matthew-
      I'm a having a problem with spaces in folder names with CFIMAP, any suggestions? besides remove the space
      Parameter 1 of function SetVariable, which is now - PS Beta 6, must be a syntactically valid variable name.
        • 1. Re: CFIMAP
          Adam Cameron. Level 5
          It's a bit difficult to say too much without seeing your actual code.
          Looks like your problem is with a setVariable() call rather than a
          call though. Speaking of which: whilst it still works, didn't
          the need to use setVariable() go the way of the dodo with... CF4 or
          • 2. Re: CFIMAP
            -Matthew- Level 1
            name="queryname" maxrows = "10" folder="#url.name#" >
            • 3. Re: CFIMAP
              Fernis Level 3
              It's still not the cfimap that causes the error in my opinion, but obviously you're using SetVariable somewhere else - and having problem with that.
              CFIMAP works for me just fine with space in folder names (tested with gmail)
              <cfimap port="993" secure="true" connection="myg" username="spaceball" password="12345"
              action="open" server="imap.gmail.com">
              Opened OK
              <cfimap connection="myg" action="getheaderonly" name="mh" folder="mega maid">
              Fetched OK
              <cfimap action="close" connection="myg">
              Closed OK
              (username/password/folder *are* (sci-)fictionary, although they just might work )
              • 4. Re: CFIMAP
                -Matthew- Level 1
                Erroneous error;
                i am almost 100% sure that the error you see has nothing to do with <cfimap> or spaces in folder names.
                my [wild] guess is that you have
                <cfparam name="#url.name# ...> <----- This was the answer
                or something like this in your page.
                the mistake here is using # in the name attribute of cfparam tag - remove them and everything should work.
                check this post by Ben Nadel for the same error you see: http://www.bennadel.com/blog/1436-Parameter-1-Of-Function-SetVariable-Which-Is-Now-FORM-Mu st-Be-A-Syntactically-Valid-Variable-Name.htm
                PS: <cfimap> has no problems accessing folders with spaces in name.
