0 Replies Latest reply on Mar 7, 2010 10:05 AM by leapdog
    Can a custom object read from disk contain an XMLListCollection?
    leapdog
      (New to posting, apologies if I don't follow protocol or explain myself clearly.)
      I'm working on a Flex AIR app which saves and reads custom objects to disk.
      I have the object, "UserVO" which I can successfully save and retrieve using FileStream.writeObject and  FileStream.readObject.
      I'm using the [RemoteClass] metadata tag, inserted before the class definition, and registerClassAlias() in my data-retrieving class. I am able to save and retrieve various String and Number properties of my custom "UserVO" objects.
      My problem is that I also want to give my UserVO class a property called "diary" which is an XMLListCollection.  However, when I attempt the load (using readObject), I get the error: TypeError: Error #1034: Type Coercion failed: cannot convert Object@d55ad09 to mx.collections.IList.
      In the Debugger, upon loading the UserVO object, I can see that "diary" exists as an XMLListCollection and that "diary" holds an XMLList as a source,
      but the XML data I thought I saved inside the XMLList is not there.
      Is this some kind of serialization issue where Flex is unable to type certain classes which are properties of custom objects?
      Or am I missing something else?
      Thanks!
