7 Replies Latest reply on Mar 11, 2010 10:51 AM by Flex harUI
    adding sprites to the app
    adamgeework Level 1
      public function onResult(responds:Object):void{
                  var main_sprite:Sprite = new Sprite();
                      searchgrid.dataProvider = responds;
                      this.rawChildren.addChild(main_sprite);
                      for(var t:uint = 0; t<responds.length; t++){
                          var txt:Text = new Text();
                          txt.text = responds[t].question;
                          txt.y = t*20;
                          main_sprite.addChild(txt);
      Is there something wrong im doing here?
      I just want my txt to be placed into main_sprite so I can clear all of mainsprite when this function runs again.
        • 1. Re: adding sprites to the app
          Flex harUI Adobe Employee
          Flex components must be parented by other Flex components.  Sprite is a
          low-level Flash Player "component".  Use UIComponent or a Container instead.
          • 2. Re: adding sprites to the app
            adamgeework Level 1
            so i've changed it to
                        var main_sprite:UIComponent = new UIComponent();
                            this.addChild(main_sprite);
                                txt.y = t*20;
            but still nothing. Keep in mind just addChild(txt); to the "main" stage works.
            • 3. Re: adding sprites to the app
              Like I said, UIComponent has no default behavoir.  Try using Canvas instead.
              • 4. Re: adding sprites to the app
                adamgeework Level 1
                i have this now:
                                    var mc:Sprite = new Sprite();
                                    var ans:Text = new Text();
                                    ans.text = responds[t].answer;
                                    mc.addChild(txt);
                                    mc.addChild(ans);
                                    mc.y = t*60;
                                    myCanvas.rawChildren.addChild(mc);
                myCanvas being a mx:Canvas and still nothing.
                I can add the textfields directly to the canvas, but not to sprite then canvas..
                • 5. Re: adding sprites to the app
                  Sprite is not a Flex component so it can't be in the mix.  Use UIComponent
                  instead of Sprite or another Canvas instead of Sprite, or make a new
                  component based on UIComponent.
                  • 6. Re: adding sprites to the app
                    adamgeework Level 1
                                     var ui:UIComponent = new UIComponent();
                                        txt.y = t*70;
                                        ans.y = txt.y + 20;
                                        ui.addChild(txt);
                                        ui.addChild(ans);
                                myCanvas.addChild(ui);
                    Something like this? sorry I dont get it because it's not working.
                    Maybe i'll just tell you want I want to do, because there may be an existing component i can just modify.
                    I want my "questions" from my database to be displayed, and when a question is clicked the question and answer will be displayed above the list.
                    I dont want it to look like some datagrid or anything. It needs to be borderless... maybe look like something that was built in flash.
                    • 7. Re: adding sprites to the app
                      Try using another Canvas instead of UICOmponent
