7 Replies Latest reply on Mar 10, 2010 1:46 AM by bodrul haque
    Combobox with a DataGrid dropdown factory runtime error
    bodrul haque
      I am getting the runtime error - ArgumentError: Error #1063: Argument count mismatch on mx.controls::ComboBox/itemToLabel(). Expected
      Any ideas?
      <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml" xmlns="*">
           <mx:ComboBox id="cb" labelField="fname">
                <mx:dataProvider>
                    <mx:Object fname="one" lname="1"/>
                    <mx:Object fname="two" lname="2"/>
                    <mx:Object fname="three" lname="3"/>
                    <mx:Object fname="four" lname="4"/>
                    <mx:Object fname="five" lname="5"/>
                </mx:dataProvider>
                <mx:dropdownFactory>
                      <mx:Component>
                            <mx:DataGrid showHeaders="false">
                                  <mx:columns>
                                       <mx:Array>
                                             <mx:DataGridColumn dataField="fname"/>
                                             <mx:DataGridColumn dataField="lname"/>
                                       </mx:Array>
                                   </mx:columns>
                            </mx:DataGrid>
                       </mx:Component>
                 </mx:dropdownFactory>
              </mx:ComboBox>
      </mx:Application>
        • 1. Re: Combobox with a DataGrid dropdown factory runtime error
          Flex harUI Adobe Employee
          Which version of the SDK?  I thought this was recently fixed.
          • 2. Re: Combobox with a DataGrid dropdown factory runtime error
            bodrul haque Level 1
            Yes it has. Just tried it on the latest nightly build(4.1.0.14607).
            Thanks Alex.
            • 3. Re: Combobox with a DataGrid dropdown factory runtime error
              No. I spoke too soon. There is one other problem.
              The RTE has been fixed but columns are showing "fname" values. Second column should be showing "lname" values.
              I've tested on the nightly build (4.1.0.14607) and stable stable build (4.0.0.13875).
              • 4. Re: Combobox with a DataGrid dropdown factory runtime error
                What does your code look like now?
                • 5. Re: Combobox with a DataGrid dropdown factory runtime error
                  Its the same code as I posted in my original post. (Its a simple example based on my flex 3 code).
                  • 6. Re: Combobox with a DataGrid dropdown factory runtime error
                    Peter deHaan Level 4
                    Looks like you can set a labelFunction to get the correct behavior:
                    <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml">
                        <mx:ComboBox id="cb" labelField="fname" dropdownWidth="200">
                            <mx:dataProvider>
                                <mx:Object fname="one" lname="1 ONE"/>
                                <mx:Object fname="two" lname="2 TWO"/>
                                <mx:Object fname="three" lname="3 THREE"/>
                                <mx:Object fname="four" lname="4 FOUR"/>
                                <mx:Object fname="five" lname="5 FIVE"/>
                            </mx:dataProvider>
                                <mx:Component>
                                        <mx:Script>
                                            <![CDATA[
                                                protected function grid_labelFunc(item:Object, col:DataGridColumn):String {
                                                    return item[col.dataField];
                                        </mx:Script>
                                        <mx:columns>
                                            <mx:Array>
                                                <mx:DataGridColumn dataField="fname" labelFunction="grid_labelFunc" />
                                                <mx:DataGridColumn dataField="lname" labelFunction="grid_labelFunc"/>
                                            </mx:Array>
                                        </mx:columns>
                                    </mx:DataGrid>
                                </mx:Component>
                        </mx:ComboBox>
                    </mx:Application>
                    You may want to file a bug at http://bugs.adobe.com/flex/ and attach your simple test case.
                    Peter
                    • 7. Re: Combobox with a DataGrid dropdown factory runtime error
                      Yes, that worked thanks. I will file a bug (I would prefer to see it working as it did in Flex 3).
                      Just to let you know, I came across an issue when making this into a mxml component. Your code works fine but when I change the example to use the "outerDocument" function notation it doesnt work (gives an RTE) eg
                      <mx:DataGridColumn dataField="fname" labelFunction="grid_labelFunc"/> // works
                      <mx:DataGridColumn dataField="fname" labelFunction="outerDocument.grid_labelFunc"/> // doesnt work
                      There is a workaround for this (full details below), so i'm not too worried.......I'd rather see the original problem get fixed.
                      Full example
                      eg 1 - MyComboBox.mxmxl - doesnt work
                      <mx:ComboBox xmlns:mx="http://www.adobe.com/2006/mxml">
                      <mx:Script>
                         <![CDATA[
                          public function grid_labelFunc(item:Object, col:DataGridColumn):String
                      </mx:Script>
                           <mx:Component>
                                        <!--mx:Script>
                                         <![CDATA[
                                                 // Move this function to outer script block
                                     </mx:Script-->
                                     <mx:columns>
                                         <mx:Array>
                                                <mx:DataGridColumn dataField="lname" labelFunction="outerDocument.grid_labelFunc"/>
                                         </mx:Array>
                                    </mx:columns>
                                 </mx:DataGrid>
                            </mx:Component>
                      </mx:ComboBox>
                      (testAPP looks like this
                      <MyComboBox/>
                      </mx:Application>)
                      this gives a runtime error
                      TypeError: Error #1009: Cannot access a property or method of a null object reference.
                      at SynComboInnerClass0/_SynComboInnerClass0_DataGridColumn1_c()[C:\Documents and Settings\bodrul haque.SYNLOG\My Documents\Adobe Flash Builder Plug-in Beta 2\myTest\src\SynCombo.mxml:63]
                      at SynComboInnerClass0()[C:\Documents and Settings\bodrul haque.SYNLOG\My Documents\Adobe Flash Builder Plug-in Beta 2\myTest\src\SynCombo.mxml:60]
                      at mx.core::ClassFactory/newInstance()[E:\dev\4.0.0\frameworks\projects\framework\src\mx\cor e\ClassFactory.as:172]
                      at mx.controls::ComboBox/getDropdown()[E:\dev\4.0.0\frameworks\projects\framework\src\mx\con trols\ComboBox.as:1678]
                      at mx.controls::ComboBox/displayDropdown()[E:\dev\4.0.0\frameworks\projects\framework\src\mx \controls\ComboBox.as:1768]
                      at mx.controls::ComboBox/downArrowButton_buttonDownHandler()[E:\dev\4.0.0\frameworks\project s\framework\src\mx\controls\ComboBox.as:2004]
                      at flash.events::EventDispatcher/dispatchEventFunction()
                      at flash.events::EventDispatcher/dispatchEvent()
                      at mx.core::UIComponent/dispatchEvent()[E:\dev\4.0.0\frameworks\projects\framework\src\mx\co re\UIComponent.as:12269]
                      at mx.controls::Button/http://www.adobe.com/2006/flex/mx/internal::buttonPressed()[E:\dev\4.0.0\frameworks\projec ts\framework\src\mx\controls\Button.as:2445]
                      at mx.controls::Button/mouseDownHandler()[E:\dev\4.0.0\frameworks\projects\framework\src\mx\ controls\Button.as:2706]
                      eg2 - this works - set label function during dg initialize event
                      <mx:ComboBox etc>
                      <mx:Script>
                        <![CDATA[
                          public function dgStartUP(e:FlexEvent):void
                               // Set label function
                               DataGrid(e.currentTarget).columns[0].labelFunction = grid_labelFunc;
                               DataGrid(e.currentTarget).columns[1].labelFunction = grid_labelFunc;
                      </mx:Script>
                           <mx:Component>
                               <mx:DataGrid showHeaders="false" initialize="outerDocument.dgStartUP(event)">
                                   <mx:columns>
                                      <mx:Array>
                                      </mx:Array>
                                   </mx:columns>
                                </mx:DataGrid>
                            </mx:Component>
                      </mx:ComboBox>
