1 Reply Latest reply on Mar 7, 2010 9:38 PM by toft
    Spark Label event problem
    toft
      Event handler for a Spark.Label control:
      private function onLabelClick(e:MouseEvent):void
      trace(e.target);
      trace(e.target.text);
      First trace returns: '[object TextLine]'
      Then I get this: ReferenceError: Error #1069: Property text not found on flash.text.engine.TextLine and there is no default value.
      What is going on here and how to fix it ??
      And: is it just me or does anyone else have LOADS of problems dealing with all the new 'improvents' in Flex 4??
      (I have to admit that I find the new spark stuff very confusing)
        • 1. Re: Spark Label event problem
          David_F57 Level 5
          Try using currentTarget.
          As far as flex 'problems', flex 4 is in beta and as things change this could be considered a problem but its beta which means expect a little confusion
          fundamentally the basic stuff still work the same, spark has a bit of a learning curve which is to be expected when a product becomes more powerful.
             xmlns:mx="library://ns.adobe.com/flex/mx" minWidth="955" minHeight="600">
          <fx:Script>
          <![CDATA[
          protected function label1_clickHandler(event:MouseEvent):void
          lblResult.text = event.currentTarget.text;
          </fx:Script>
          <fx:Declarations>
          <!-- Place non-visual elements (e.g., services, value objects) here -->
          </fx:Declarations>
          <s:Label x="148" y="85" text="A Label that is clickable" click="label1_clickHandler(event)"/>
          <s:Label id="lblResult" x="148" y="115" text="result"/>
          </s:Application>
