0 Replies Latest reply on Mar 8, 2010 7:26 AM by Paul Reilly
    [svn:sb-sherlock] 14621: * Fixed some JUnit test failures caused by revision 14005.
    Paul Reilly Level 1
      Revision: 14621
      Revision: 14621
      Author:   preilly@adobe.com
      Date:     2010-03-08 07:26:00 -0800 (Mon, 08 Mar 2010)
      Log Message:
      • Fixed some JUnit test failures caused by revision 14005.
      QE notes:
      Doc notes:
      Bugs: SHERLOCK-6
      Reviewer: Tom H.
      Tests run: checkintests, JUnit tests
      Is noteworthy for integration: no
      Code-level description of changes:
        SwcLazyReadArchive.java
          Added back close() to handle closing the ZipFile at the end of a
          compilation.  Otherwise too many file handles are left open by the
          global swc cache.
        SwcDirectoryArchive.java
          Modified fileList to be lazily initialized.  This makes
          SwcDirectoryArchive consistent with SwcLazyReadArchive.
      Ticket Links:
          http://bugs.adobe.com/jira/browse/SHERLOCK-6
      Modified Paths:
          flex/sdk/sandbox/sherlock/modules/compiler/src/java/flex2/compiler/swc/SwcDirectoryArchiv e.java
          flex/sdk/sandbox/sherlock/modules/compiler/src/java/flex2/compiler/swc/SwcLazyReadArchive .java
