0 Replies Latest reply on Mar 8, 2010 8:05 AM by Paul Reilly
    [svn:fx-trunk] 14622: * Two unrelated compiler fixes.
    Paul Reilly Level 1
      Revision: 14622
      Revision: 14622
      Author:   preilly@adobe.com
      Date:     2010-03-08 08:05:27 -0800 (Mon, 08 Mar 2010)
      Log Message:
      • Two unrelated compiler fixes.
      QE notes:
      Doc notes:
      Bugs: SDK-25206, SDK-25619
      Reviewer: pfarland
      Tests run: checkintests
      Is noteworthy for integration: no
      Code-level description of changes:
        media/FontTranscoder.java
          Modified getURL() to handle all non-LocalFile VirtualFiles by
          piping the input stream to a temp file and then returning the URL
          for the temp file.  We were previously only handling SwcFile
          instances, but due to global SWC cache optimizations,
          InMemoryFile's can now be passed in.
        CompilerAPI.java
          Modified validateCompilationUnits() to artificially insert
          "Namespace" as a dependency, so we can detect when a recompilation
          is necessary when switching between airglobal.swc and
          playerglobal.swc.
      Ticket Links:
          http://bugs.adobe.com/jira/browse/SDK-25206
          http://bugs.adobe.com/jira/browse/SDK-25619
      Modified Paths:
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/CompilerAPI.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/media/FontTranscoder.java
