7 Replies Latest reply on Mar 13, 2010 9:32 AM by AdobeScripts
    FindText problem
    Makkanj
      Hi
      Why doesn’t the code bellow find textToSearchFor in txt.Contens in CS4 with the method FindText?
      txt.Contens= "!B!bla bla bla!/B!. Bla bla bla bla. _"
      textToSearchFor="!B!"
          Private Function FindTextWrapper(ByVal txt As InDesign2CS.Text, ByVal textToSearchFor As String) As InDesign2CS.Objects
              Dim retObj As InDesign2CS.Objects
              If _MyIndesignApp.Version < "6" Then
                  retObj = txt.Search(textToSearchFor, False, False, )
              Else
                  _MyIndesignApp.FindTextPreferences = InDesign2CS.idNothingEnum.idNothing
                  ' Hämta alla startpunkter för bold
                  _MyIndesignApp.FindTextPreferences.FindWhat = textToSearchFor
                  retObj = txt.FindText()
              End If
              Return retObj
          End Function
      Any idea?
      /Magnus
        • 1. Re: FindText problem
          Harbs. Level 6
          Maybe try:
          txt.Contents
          instead of:
          txt.Contens
          Harbs
          • 2. Re: FindText problem
            Makkanj Level 1
            Sorry, wrong spelling of me in the text.
            In my program the txt.Contents is:
            txt.Contents= "!B!bla bla bla!/B!. Bla bla bla bla. _"
            • 3. Re: FindText problem
              Harbs. Level 6
              I'm not a VB man, but it does not look like full code. Can you give us a piece of working (or not working) code which illustrates the problem?
              Harbs
              • 4. Re: FindText problem
                Makkanj Level 1
                It's hard to give a good code example because there are a lot of code involved. But the code who calls the method looks like this:
                Code:
                TextFrame.ParentStory.Texts.ItemByRange(TextFrame.ParentStory.Texts.Item(1).Characters.Ite m(1), TextFrame.ParentStory.Texts.Item(1).Characters.item(TextFrame.ParentStory.Texts.Item(1).C haracters.Count - 1)).Item(1).Contents = "!B! bla bla "
                StartObj = FindTextWrapper(TextFrame.ParentStory.Texts.Item(1), "!B!")
                Output:
                StartObj.count = 0
                In some cases the findText method finds textToSearchFor in txt but in other cases not.
                • 5. Re: FindText problem
                  Makkanj Level 1
                  Hi again!
                  Just found out what was causing the problem.
                  If the layer is invisible than findtext will not find the text.
                  Is there a workaround for this, still having an invisible layer?
                  Best Regards
                  • 6. Re: FindText problem
                    Harbs. Level 6
                    FindChangeTextOption.includeHiddenLayers
                    Harbs
                    • 7. Re: FindText problem
                      AdobeScripts Level 3
                      Makkanj wrote:
                      Code:
                      TextFrame.ParentStory.Texts.ItemByRange(TextFrame.ParentStory.Texts.Item(1).Characters.Ite m(1), TextFrame.ParentStory.Texts.Item(1).Characters.item(TextFrame.ParentStory.Texts .Item(1).Characters.Count - 1)).Item(1).Contents = "!B! bla bla "
                      You don't need to refer to ParentStory:
                      TextFrame.Texts.ItemByRange( _
                      TextFrame.Characters.Item(1), _
                      TextFrame.Characters.Item(-2) _
                      ).Item(1).Contents = "bla bla"
                      But first - even in your example - you need to check number of characters in TextFrame
                      robin
                      www.adobescripts.com
