8 Replies Latest reply on Mar 9, 2010 7:38 AM by the_wine_snob
    Output jpg file cropped
    cjacs2
      Dear All
      Im new to this forum, indeed fairly new to Prem Pro CS4.
      I am importing jpeg files, 4256 x 2832. These look perfect on the preview monitor but when played back on the timeline, the playback monitor shows the image cropped both at the top/bottom/right/left sides quite a lot. I have set the image to 'Fit' and 100% but makes no difference.
      Any ideas would be greatly appreciated
      Many thanks for your help
      Regards
      Chris Anderson
        • 1. Re: Output jpg file cropped
          the_wine_snob Level 9
          Chris,
          First, you need to turn Scale to Frame OFF.
          Next, PrPro can only handle images up to ~ 4096 pixels on the largest dimension.
          Then, you are better of sizing your images in PS, prior to Import. The Scaling algorithms in PS are better, and offer more control, than those in PrPro - it is a video editing program and not am image editor. The quality will be better. This is one time, where bigger is NOT better.
          What is your Project/Sequence Frame Size (from the chosen Preset)? That is about where you will want to resize to.
          PS - Welcome to the forum!
          • 2. Re: Output jpg file cropped
            This ARTICLE will give you some more background on Scaling stills in PS, and offer tips on automating this with Actions.
            Good luck, and hope that this helps,
            • 3. Re: Output jpg file cropped
              Welcome to the forums.
              Rightclick on the still in the timeline and scale to fit framesize or
              scale it under Motion in the Effects Controle.
              When the still gives trouble on playback you need to scale it down to sequence size before importing.
              Or when doing pan/zoom scale it to twice the sequence size.
              • 4. Re: Output jpg file cropped
                cjacs2 Level 1
                Hi Ann
                Many thanks for your quick reply. I did what you suggested, and that made things much better, but i still get a black border right/left. I guess
                this is because my jpeg is 4256 and the max adobe supports is 4000 ? -  I dont fully understand, as if the jpeg looks perfect in the preview
                window then adobe most be able to import that ok.
                Also, i have 100 jpeg files to import, will i have to do this for every file ? - i was hoping to do a presentation of photos with sime transitions
                and thought it may be simple!!!!
                Thanks again
                Chris
                • 5. Re: Output jpg file cropped
                  cjacs2 Level 1
                  Hunt,
                  how to I do that?
                  >Then, you are better of sizing your images in PS, prior to Import. The Scaling algorithms in PS are better, and offer more control, than those in PrPro - it >is a video editing program and not am image editor. The quality will be better. This is one time, where bigger is NOT better.
                  Ok will take a look but never used PS. I have 100 jegs to import, will i have to work on each one individually ? - thats gonna take some time
                  when i was hoping just to import some photos, add some transitions and play!
                  Can you please point me to where i find this, sorry to be a pain
                  Thanks again
                  Chris
                  • 6. Re: Output jpg file cropped
                    Chris,
                    The linked article steps you through automating the Scaling in PS. I start with one folder of my source files, the Source Folder, set up my Action to do the necessary Scaling, and then choose a Destination Folder for the output. On my workstation, a folder of 100 JPEG's would probably take 5 mins. to process if I have the Override Open Command on. About the time to go and make a cup of coffee.
                    • 7. Re: Output jpg file cropped
                      cjacs2 Level 1
                      Many thanks for your help, much appreciated. Im off to dabble with PS!
                      Chris
                      • 8. Re: Output jpg file cropped
                        Chris,
                        Good luck with PS. It's a great and very powerful program. I use it so much and for so many things in PrPro.
                        Have fun,
