5 Replies Latest reply on Jan 25, 2009 4:49 AM by Newsgroup_User
    Editable region not editable message
    nyipl
      I've created a template with the content area marked as editable. When I create a new file from this template, then make changes in the region marked as editable, I get an error message when I try to validate the code saying I've made changes to code that is not editable. I'm attaching the relevant part of the code. In this sample, I get the message when I try to change the text "lglg elements" which as far as I can see should be editable.
      Thank you for any help!
      Janet
        • 1. Re: Editable region not editable message
          Level 7
          That message is thrown whever the template engine encounters an error on the
          page, related or unrelated to your template markup, so it's a bit of a red
          herring.
          Does the page validate when you go here?
          http://validator.w3.org
          Murray --- ICQ 71997575
          Adobe Community Expert
          (If you *MUST* email me, don't LAUGH when you do so!)
          http://www.projectseven.com/go - DW FAQs, Tutorials & Resources
          http://www.dwfaq.com - DW FAQs, Tutorials & Resources
          "nyipl" <webforumsuser@macromedia.com> wrote in message
          news:glfacb$lof$1@forums.macromedia.com...
          > create
          > I've
          > of
          > "lglg
          > Janet
          > <!-- start page -->
          > <div id="page">
          > <!-- start content -->
          > <!-- InstanceBeginEditable name="MainContent" -->
          > <div id="content">
          > <div class="post">
          > <h1 class="title">lglg elements</h1>
          > <div class="entry">
          > <p>entry class paragraph</p>
          > <p>another entry class paragraph</p>
          > </div>
          > </div>
          > </div>
          > <!-- InstanceEndEditable -->
          > <!-- end content -->
          > <!-- start sidebar -->
          • 2. Re: Editable region not editable message
            nyipl Level 1
            That's a good site to know about. I'll use that in the future.
            As for this problem, I published the file as it was created from the template without trying to make any changes, and I went to that website to validate it. I got the message "This document was successfully checked as XHTML 1.0 Strict!" This newly-created file is also validated as correct in Dreamweaver.
            The page that I published without modifying it is at http://www.lglg.org/elements/products.html. (I'm using one of the Free CSS Templates.) When I simply try to change the title text "lglg elements" to "products" I get the message that I'm trying to change something that's not editable.
            Thank you for any further ideas about this!
            Janet
            • 3. Re: Editable region not editable message
              Level 7
              Try changing this in the Template page -
              <div id="sidebar">
              <ul>
              <li>
              <h2><strong>elements</strong> resources</h2>
              <ul>
              to this -
              <div id="sidebar">
              <ul>
              <li>
              <p><strong>elements</strong> resources</p>
              <ul>
              and see if you still get that error. I don't think you can have an <h#> tag
              inside a <li> element.
              news:glfgjb$sjm$1@forums.macromedia.com...
              > Hi,
              > template
              > it.
              > Strict!"
              > not
              > editable.
              > Janet
              • 4. Re: Editable region not editable message
                nyipl Level 1
                Hi Murray,
                I tried it (See source for http://www.lglg.org/elements/products.html) but I still have the problem. Actually, I've used <h#> inside <li> before and it hasn't seemed to complain.
                (For example, see http://www.lglg.org/index.html .)
                Janet
                • 5. Re: Editable region not editable message
                  Level 7
                  Zip the template, the child page, and the dependent files, and email them to
                  me at -
                  forums at great-web-sights dot com
                  news:glfq2g$9sd$1@forums.macromedia.com...
                  > Hi Murray,
                  > I
