2 Replies Latest reply on Mar 8, 2010 2:17 PM by TestOCM
    [JS] Date Variable in File Path
    TestOCM
      Hello,
      I have simple script that is placing files on to the page.
      var myDate = new Date();
      var myDay=myDate.getDate();
      var myMonth=myDate.getMonth() + 1;
      var myYear=myDate.getFullYear();
      var myTotal = myDay + "/" + myMonth + "/" + myYear;
      var afile = File("/Files/max/Desktop/'myTotal'_name.txt") >>>>Could please someone suggest how I can use variable myTotal - as prefix for the name of the file ? I need to open files with actual date
      var bfile = File("/Files/max/Desktop/b.txt")
      var cfile = File("/Files/Max/Desktop/c.txt")
      if (!afile.exists || !bfile.exists || !cfile.exists)
      alert ("Text file missing...")
      else
      myDoc.textFrames.item("a").parentStory.insertionPoints.item(-1).place(afile);
      myDoc.textFrames.item("b").parentStory.insertionPoints.item(-1).place(bfile);
      myDoc.textFrames.item("c").parentStory.insertionPoints.item(-1).place(cfile);
      Thank you
        • 1. Re: [JS] Date Variable in File Path
          The argument to File(...) is a simple text string, and simple text strings are concatenated using the + operator:
          a = "b";
          b = "c";
          c = a+b; -> c = "bc";
          You are complicating things by mixing both single and double quotes. Javascript accepts either, but the same ones must be used for both opening and closing a string.
          Instead of
          use
          ("/Files/max/Desktop/"+myTotal+"_name.txt")
          By the way, as you can see in your own File(..) line, the forward slash is defined as a path separator. It's possible you have a folder structure "Files", containing "max", containing "Desktop", but since you add 'myTotal' to the mix -- which also contains forward slashes -- you have to ensure all path elements in that exist as well.
          (As it seems you were not intending that, I'd suggest using other date separators than forward -- or backward! -- slashes.)
          • 2. Re: [JS] Date Variable in File Path
            TestOCM Level 1
            Thank You that was easy....
            I will take your suggestions ...
            I did change slashes to underscore in date...
            CHeers
