2 Replies Latest reply on Mar 9, 2010 7:45 PM by satheeshpallath12
    Stratus- No Connection
    satheeshpallath12
      Hai sir,
      We got connection last week in our system.We enabled all the UDP ports >1023 to "stratus.adobe.com".But after that day onwards,we are not able to connect to stratus.Is there any problem on stratus or in our system?
      can any one let me know what happen to us?
      PLZ  Reply....
      Ad Thanx...
        • 1. Re: Stratus- No Connection
          Michael Thornburgh Adobe Employee
          Stratus has many IP addresses beyond the two that are listed in the DNS records for "stratus.adobe.com".  in order to reliably connect to Stratus, you must be able to communicate with all of them on any UDP port > 1023.  the IP addresses and UDP ports that Stratus uses are subject to change at any time.
          a connection to Stratus is not useful unless you can also communicate directly with other clients, which means having bidirectional access to *any* IP address and UDP port number > 1023.
          • 2. Re: Stratus- No Connection
            satheeshpallath12 Level 1
            Hai sir,
            We enabled the UDP ports in bidirectional.We got the text conversation also.But  after that, not getting  connection to stratus.Always showing the "Failure " alert.Is there any problem to stratus connection?
            This is my code.....
            <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml" layout="absolute" creationComplete="connect()">
                <mx:Script>
                    <![CDATA[
                    import flash.events.NetStatusEvent;
                    import flash.net.NetConnection;
                    import mx.controls.Alert;
                    private const StratusAddress:String = "rtmfp://stratus.adobe.com";
                    private const DeveloperKey:String ="Developer ID";
                    private var nc : NetConnection;
                    private function connect():void
                        nc = new NetConnection();
                       nc.addEventListener(NetStatusEvent.NET_STATUS, netConnectionHandler);
                        nc.addEventListener(AsyncErrorEvent.ASYNC_ERROR, asyncErr);
                        nc.connect(StratusAddress+ "/" +DeveloperKey);
                    private function netConnectionHandler(event:NetStatusEvent):void
                        Alert.show(event.info.code);
                 switch (event.info.code)
                 case "NetConnection.Connect.Success":
                  t1.text = event.info.code;
                   t2.text = nc.nearID;
                   break;
                   case "NetConnection.Connect.Failed":
                   Alert.show("Connection Failed");
                     t1.text = "Failed";
                   break;
                    case "NetConnection.Connect.Rejected":
                  Alert.show("Connection Rejected");
                     case "NetStream.Play.StreamNotFound":
                      Alert.show("Stream not Found", "Error");
                       break;
                    private function asyncErr(event:AsyncErrorEvent):void
                </mx:Script>
                <mx:TextArea x="226" y="41" width="50%" id="t1"/>
                <mx:TextArea x="226" y="110" id="t2" width="407"/>
                <mx:Text x="150" y="41" text="Status" height="44" width="68" fontWeight="bold" fontSize="15"/>
                <mx:Text x="159" y="110" text="ID" width="44" height="44" fontWeight="bold" fontSize="15"/>
            </mx:Application>
            Plz Reply.....soon....
            Ad Thanx
