1 Reply Latest reply on Oct 10, 2006 1:24 PM by jmcclintick
    Radio Buttons
    brandon_haslip Level 1
      I have built a flash movie that has 8 options which you can turn ON and OFF via radio buttons. Some of the options can not be on at the same time as others. (Example: Option 3 cannot be ON at the same time as Option 6.)
      Is there some code that I can attach to the radio buttons so that if Option 3 is turned ON and the user then clicks Options 6 ON, it will turn Option 3 to OFF?
      Any help would be greatly appreciated. Thanks.
        • 1. Radio Buttons
          jmcclintick
          well I think you can do an event handler when you click a radio button so you can probably check to see which ones are clicked when you click 6 and if 8 is clicked then disable it. go to the radio button and put an action on it like
          on (click) {
          whatever youw ant to do;
          you would do this for the 2 buttons you want to make sure are not on at the same time. maybe this will help idk good luck!
