• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
CFLOOP List
New Here ,
Sep 06, 2007 Sep 06, 2007
Im wanting to loop some records, each record has a list of division ids in a field called divverify.
I want to run a query inside the loop against each id in the fields so that an email gets sent out to all the id numbers.
It is throwing me an error - probably because it is trying to list all the ids at once, and not individually after every loop. How can I achieve this?
Here is the error:
Error Executing Database Query.
The multi-part identifier "seldealer.divverify" could not be bound.
24 : SELECT *
25 : FROM loldivlist
26 : WHERE divid=#i#
27 : </CFQUERY>
::::::::::::::: Here is the CODE :::::::::::::::
TOPICS
Advanced techniques
Views
885
Translate
Translate
Report
Report
Community guidelines
community guidelines
Community Beginner , Sep 06, 2007 Sep 06, 2007
Try using the query attribute of cfloop to loop through all the records in the first query. Although if the first query returned a single record where divverify is a list, you had it right but you need to do list="#seldealer.divverify#".
-Tim
Votes
Translate
Translate
-Tim
Votes
Translate
Translate
Report
Report
New Here ,
I am wanting to loop thru the list contained in the divverify field - the example you gave me will loop thru the dealers - I need to loop thru the divisionid's (in essence the divisions) to email the divisions associated with that dealer area to send the division an email. How do I query each divisionid in that list one at a time and loop at the same time?
Votes
Translate
Translate
Report
Report
New Here ,
Nevermind - I just saw what you pointed out I did wrong - I did not put the ## signs around the list variable - that was it and it worked great. I was so CLOSE!!! : )
Thanks bud!
Votes
Translate
Translate
Report
Report
Guide ,
Storing multiple values in a single field complicates code unnecessarily. Its also a bad design choice as it violates normalization rules.
Votes
Translate
Translate
Report
Report
New Here ,
What would be a better solution?
Votes
Translate
Translate
Report
Report
Guide ,
Sounds like you have a many-to-many relationship. Meaning one dealer(?) belongs to many divisions (?). Instead of storing the division ids in a single column like this
DealerID| DivVerify
1 | 2,4,18
You should store them in a separate table, with each dealer/divisionID in a separate row.
Table name: DealerDivision
DealerID, DivisionID
1 , 2
1 , 4
1 , 18
Then you could use a single query to retrieve your results instead of using cfloop.
Votes
Translate
Translate
Report
Report
New Here ,
Sep 07, 2007 Sep 07, 2007
This DIVverify is a "temp" field, which is only used if the dealer has not been assigned a division yet. What my goal was, is too put a list of division into one field, and then email each division in that field asking the division if this is there dealer. Once a dealer is claimed by a division, this field is wiped clean and never used again.
My second challenge is, how do I remove a specific id from this list, so that if the division says "nope, not my dealer", that I can remove their divisionid number from the list. If there was a way to determine the position of the list element, then I could use ListDeleteAt() function and tell it to delete that position...is there a way to determine list position for a specific list element?
I thought this would be the best and easiest way of working with these temp variables without creating another table.
Votes
Translate
Translate
Report
Report
New Here ,
LATEST
ListFind() - found it!
Votes
Translate
Translate
Report
Report
Contributor ,
"Normalization"??? Say it aint so?
LOL
I'm glad I read to the end of the posts because I was about to say "NORMALIZE YOUR DATABASE!"
Votes
Translate
Translate
Report
Report
Contributor ,
Let me point out something else too.
In the first query you are grabbing everything "SELECT *" but you are only using seldealer.divverify You should only select what you are going to use. Saves time and bandwidth and memory.
Votes
Translate
Translate
Report
Report
Resources
Documentation
