1 Reply Latest reply on Mar 17, 2010 10:27 PM by sundeep.maithani
    Adobe air on OLPC (linux)
    TPlessis
      Hi guys,
      I'm trying to install adobe air on OLPC (http://laptop.org/en/). It's a custom linux based on a fedora distrib. When i tried to run installation of air, i'v the following message at the end of the installation :
      An error occurred while installing Adobe AIR. Installation may not be allowed by your administrator. Please contact your administrator.
      Here is the content of the .airinstall.log file :
      Performing runtime install
      UI SWF load is complete
      UI initialized
      starting user confirmation
      Version of this installer: 1.5.3.9130
      Installation type: new
      starting elevated install
      subinstaller: starting install
      subinstaller: Scheduling runtime installation operations
      subinstaller: Session detected: GNOME
      subinstaller: new installation
      subinstaller: Beginning runtime installation
      subinstaller: Beginning install
      subinstaller: Copying /tmp/air.PKh2aG/build/opt/Adobe AIR/Versions/1.0/Resources/setup.deb to /tmp/air.PKh2aG/setup.deb
      subinstaller: Error occurred; beginning rollback: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="/tmp/air.PKh2aG/build/opt/Adobe AIR/Versions/1.0/Resources/rpmbuilder error : symbol not found: rpmErrorString, /usr/lib/librpmbuild.so: undefined symbol: rpmErrorString
      received unknown message type from subinstaller:
      received unknown message type from subinstaller: symbol not found: rpmErrorCode, /usr/lib/librpmbuild.so: undefined symbol: rpmErrorCode
      received unknown message type from subinstaller: gpg: skipped "%{_gpg_name}": secret key not available
      received unknown message type from subinstaller: gpg: signing failed: secret key not available
      received unknown message type from subinstaller:  error : error: Recursion depth(17) greater than max(16)
      received unknown message type from subinstaller:  15<                               (empty)
      received unknown message type from subinstaller:  14<                             (empty)
      received unknown message type from subinstaller:  13<                           (empty)
      received unknown message type from subinstaller:  12<                         (empty)
      received unknown message type from subinstaller:  11<                       (empty)
      received unknown message type from subinstaller:  10<                     (empty)
      received unknown message type from subinstaller:   9<                   (empty)
      received unknown message type from subinstaller:   8<                 (empty)
      received unknown message type from subinstaller:   7<               (empty)
      received unknown message type from subinstaller:   6<             (empty)
      received unknown message type from subinstaller:   5<           (empty)
      received unknown message type from subinstaller:   4<         (empty)
      received unknown message type from subinstaller:   3<       (empty)
      received unknown message type from subinstaller:   2<     (empty)
      received unknown message type from subinstaller:   1<   (empty)
      received unknown message type from subinstaller:   0< (empty)
      received unknown message type from subinstaller: error: failed to create directory %{_topdir}: : No such file or directory
      received unknown message type from subinstaller: " errorID=1]
      subinstaller: Deleting /tmp/air.PKh2aG/setup.deb
      subinstaller: Error during rollback ignored: [IOErrorEvent type="ioError" bubbles=false cancelable=false eventPhase=2 text="Error #3003" errorID=3003]
      subinstaller: Rollback due to error complete
      subinstaller: error during install: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="/tmp/air.PKh2aG/build/opt/Adobe AIR/Versions/1.0/Resources/rpmbuilder error : symbol not found: rpmErrorString, /usr/lib/librpmbuild.so: undefined symbol: rpmErrorString
      Failed during elevated install: error 1 /tmp/air.PKh2aG/build/opt/Adobe AIR/Versions/1.0/Resources/rpmbuilder error : symbol not found: rpmErrorString, /usr/lib/librpmbuild.so: undefined symbol: rpmErrorString
      runtime install entering error state: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="/tmp/air.PKh2aG/build/opt/Adobe AIR/Versions/1.0/Resources/rpmbuilder error : symbol not found: rpmErrorString, /usr/lib/librpmbuild.so: undefined symbol: rpmErrorString" errorID=1]
      begin quitting
      I've try to update rpm-builder packages, but it doesn't change anything... any ideas?
      Tom
