7 Replies Latest reply on Mar 10, 2010 12:18 PM by Jeff Bellune
    Video Jumps & Skips after Exporting...HELP!
    cclins3
      Hello All,
      I am working with AVCHD footage in Premiere Pro & After Effects (using dynamic link).  All of the clips in the Premiere Pro sequence I have used the "Replace with After Effects Composition".  I am using After Effects mainly for keying out the green screen in my footage.  I "Export" the sequence from Premiere Pro (QuickTime:MPEG-4) and when I play the 3:37 video, the first 1:39 has 20 clips that are jumpy and skip.  There are also some clips in the beginning of the video that don't experience any sort of jumpy picture.
      I am very confused & frustrated because the second half of the video is perfect.  I even use some of the same footage in the beginning of the video in the end so it doesn't make sense that it skips & jumps in the beginning and not in the end!?
      It is tough for me to explain so here is a link to see the problem & hopefully some of  you have seen this and know how to fix it.
      I am current with all updates for all my Adobe software (Adobe Production Premium CS4) so I don't believe this to be the issue.
      In the clip, the beginning shows 2 different shots that are jumpy then you'll see the same shots (towards the end of the video) that don't jump.
      http://cid-1351a668967d6941.skydrive.live.com/self.aspx/.Public/HELP.mov?lc=1033
