1. Re: auto update not rendering on version 1.5.3.9130
tzengMar 10, 2010 7:31 PM (in response to shawntherrien)
Is your new update a 1.5.3
app.? If it is, do you set the publisher ID correctly?
Have you tested the update process?
2. Re: auto update not rendering on version 1.5.3.9130
aili Li Mar 11, 2010 12:39 AM (in response to shawntherrien)If your application packaged with Flex SDK 3.5 , the application update UI is broken. But this problem has been fixed on SDK3.5a, you can get it in here:
http://opensource.adobe.com/wiki/display/flexsdk/Download+Flex+3
3. Re: auto update not rendering on version 1.5.3.9130
shawntherrien Mar 11, 2010 7:38 AM (in response to tzeng)it has been working on 1.5.3.9120 up until this last update of 1.5.3.9130
not sure what you mean by 1.5.3 app but it uses the latest versions and I
always test the process on my machine before rolling it out. but I'm on a
mac with osx 10.6 and it worked for me but on windows xp and osx 10.4 it
doesn't. after getting some complaints i tested it on xp and it failed.
4. Re: auto update not rendering on version 1.5.3.9130
Mihai BalanMar 11, 2010 11:22 AM (in response to shawntherrien)
Hi shawntherrien,
I tried to reproduce you issue, but to no avail. Could you provide us with a little more details. Specifically:
- what version of the AIR SDK / Flex SDK are you using to compile and package your app? (you can find the Flex SDK version in the flex-sdk-description.xml file in the FlexSDK installation folder; running FLEX_SDK_FOLDER/bin/adt -version in a console will give you the AIR SDK version)
- did you use a more recent AIR SDK version than the Flex SDK version?
- my understanding of the way this bug manifests is the following (please correct me if I'm wrong):
- you developed both version N and version N+1 of the application using the same Flex/AIR SDK
- users installed version N on AIR Runtime 1.5.3.9120
- users updated their AIR Runtime to 1.5.3.9130
- users were unable to upgrade to version N+1 as the update dialog would not come up properly (renders incompletely)
If you're using Flex 3.5, did you try aili Li's suggestion to upgrade to Flex 3.5.a?
Hope this helps,
Mihai
5. Re: auto update not rendering on version 1.5.3.9130
shawntherrien Mar 12, 2010 5:10 AM (in response to Mihai Balan)I'm running the latest version of flex 3.5a which is the flex_sdk_3.5.0.12683 with air sdk Adobe AIR 1.5.3 SDK
no, I'm running the air sdk stated in the forum which is 1.5.3.9130 which I installed right before the update
yes this is the correct sequence of events it seems odd to me because adobe has asked that I update my Flex version to 3.5a but I had already done so before with the previous version of my app. when they installed with 1.5.3.9120.I reinstalled everything so maybe my installation was bad I will post again and see if that fixed the problem.
-Thanks
6. Re: auto update not rendering on version 1.5.3.9130
shawntherrien Mar 12, 2010 8:21 AM (in response to shawntherrien)Hi all,
I found where the issue was in my process it was the app.xml pointing to the old version of air namespace
application xmlns="http://ns.adobe.com/air/application/1.5.2 instead of application xmlns="http://ns.adobe.com/air/application/1.5.3
once this was fixed which needs added to the touble shooting tips for adobe everything started working again. so even if you compile everything in 3.5a you will still have issue unless you change this. very easy to miss
