0 Replies Latest reply on Mar 10, 2010 1:21 PM by jmurphy67
    [svn:fx-4.0.0] 14683: rollback revs 14184 & 14288.
    jmurphy67 Level 1
      Revision: 14683
      Revision: 14683
      Author:   jimurphy@adobe.com
      Date:     2010-03-10 13:21:27 -0800 (Wed, 10 Mar 2010)
      Log Message:
      rollback revs 14184 & 14288.  These changes are not part of our RC build 14159, and should not be included when we create a tag.
      QE notes: no
      Doc notes: no
      Bugs: no
      Reviewer: gaurav
      Tests run: no
      Is noteworthy for integration: no
      Modified Paths:
          flex/sdk/branches/4.0.0/modules/compiler/src/java/flex2/compiler/CompilerAPI.java
          flex/sdk/branches/4.0.0/modules/compiler/src/java/flex2/compiler_da.properties
          flex/sdk/branches/4.0.0/modules/compiler/src/java/flex2/compiler_de.properties
          flex/sdk/branches/4.0.0/modules/compiler/src/java/flex2/compiler_en.properties
          flex/sdk/branches/4.0.0/modules/compiler/src/java/flex2/compiler_es.properties
          flex/sdk/branches/4.0.0/modules/compiler/src/java/flex2/compiler_fi.properties
          flex/sdk/branches/4.0.0/modules/compiler/src/java/flex2/compiler_fr.properties
          flex/sdk/branches/4.0.0/modules/compiler/src/java/flex2/compiler_it.properties
          flex/sdk/branches/4.0.0/modules/compiler/src/java/flex2/compiler_ja.properties
          flex/sdk/branches/4.0.0/modules/compiler/src/java/flex2/compiler_ko.properties
          flex/sdk/branches/4.0.0/modules/compiler/src/java/flex2/compiler_nb.properties
          flex/sdk/branches/4.0.0/modules/compiler/src/java/flex2/compiler_nl.properties
          flex/sdk/branches/4.0.0/modules/compiler/src/java/flex2/compiler_pt.properties
          flex/sdk/branches/4.0.0/modules/compiler/src/java/flex2/compiler_ru.properties
          flex/sdk/branches/4.0.0/modules/compiler/src/java/flex2/compiler_sv.properties
          flex/sdk/branches/4.0.0/modules/compiler/src/java/flex2/compiler_zh_CN.properties
          flex/sdk/branches/4.0.0/modules/compiler/src/java/flex2/compiler_zh_TW.properties
      Property Changed:
