4 Replies Latest reply on Mar 10, 2010 10:16 PM by Harry Kunz
    Date and Time
    krish_laugh Level 1
      hi all
      In a Text field I want to display the Milliseconds in 2 digits only
      example      05    :   30  :   23   :   00
                       Hour     Mins   Sec     Milliseconds
      for this i just convert the milliseconds in toStrings
      and using substr(0,2)
      if we do like this it shows the milliseconds in 2 digits
      example  05 : 30 : 23 : 01
      but it shows in 1 digits if milliseconds was in 2 digits
      example  05 : 30 : 23 : 1
      how to clear this
      am i doing right
        • 1. Re: Date and Time
          Show all of the code you are using,  Also, what happens for 3 digit milliseconds since you only want to display 2 digits (milliseconds < 1 second will range from 0 thru 999)?
          • 2. Re: Date and Time
            Harry Kunz Level 4
            You can use a prepend-"0" routine before after it is converted to string assuming you already have the time in milliseconds stored in the variable nTime like this:
            var sTime:String = nTime.toString();
            while(sTime.length < 4) sTime = "0" + sTime;
            sTime = sTime.substr(0,2);
            This will return values 00 through 09 for millisecond values of 0000 to 0999. Notice that the fourth digit will always be zero because when it reaches 1000 it should be zero while the seconds variable is incremented. Since the first digit is always zero, i would suggest you better display values 0 through 9 instead of 00 through 09 by using:
            while(sTime.length < 3) sTime = "0" + sTime;
            sTime = sTime.substr(0,1);
            • 3. Re: Date and Time
              krish_laugh Level 1
              Hi Hurry
              can we use any code directly without converting it into string
              one of my friend told me it is unnecessary
              is there any script for problem
              • 4. Re: Date and Time
                Harry Kunz Level 4
                The end result should always be a string since you are going to set a text field with a number. So you may drop the loop and the string method substr. Take note though that your values will only be 00 to 09 as explained above, so you could just do something as simple as this one liner:
                txt.text = "0" + int(nTime * 0.01);
                Or if you would like the values to be displayed from 000 to 999 you can use this
                if(nTime < 10) sTime = "00" + sTime;
                else if(nTime < 100) sTime = "0" + sTime;
                yourtextfield.text = sTime;
                Or if you would like the values to be displayed with the extra zero from 0000 to 0999 (1000 becomes 0000 and seconds is incremented), you can prepened an extra zero to the last line:
                yourtextfield.text = "0" + sTime;
                Where nTime = millisecond value from 0 to 999. This is the the most efficient you can do.
