2 Replies Latest reply on Mar 11, 2010 5:57 AM by Sam Souhrada
    How to get Checkbox Value from Flex in PHP.
    minetgate
      I need to know how to get a checkbox value from flex in PHP-POST/GET because I don't know what is the value property of a checkbox in flex.
      Please Help.
        • 1. Re: How to get Checkbox Value from Flex in PHP.
          TanweerHq Level 2
          It is very simple. Follow the steps below to achieve the solution,
          1. Write a check-box change event to capture the value of the check box. Store this value in a variable(say bolChkSelected:Boolean).
          2. In step 1 you got the value of the check box. Now your aim is to send the value to php. Declare a httpService in your flex application(i think you are aware of using it).Ok..im writing it
          <mx:HTTPService id="sampleService" resultFormat='e4x' url='http://yourdomain/file.php' result='handleResult()' fault='handleFault()'>
          </mx:HTTPService>
          3. Now the actual solution... u need to send the shcStatus in to php..
          Declare an object to hold the data
          var objparameters:Object={};
          objparameters['CheckBoxdata'] = bolChkSelected;
          --in the above line... 'CheckBoxdata' is used as a parameter to php..you shud have the same variable name while accessing in php file also..
          in php file..
          checkboxstatus = $_POST[''CheckBoxdata''];
          echo checkboxstatus
          thats it..
          • 2. Re: How to get Checkbox Value from Flex in PHP.
            Sam Souhrada
            Here is a very basic example of sending data to/from PHP:
            http://www.riaindy.com/adobe/2010/02/adobe-flex-php-integration/
            This could easily be converted to sending a true or false value for a checkbox.
