0 Replies Latest reply on Mar 10, 2010 6:27 PM by jmurphy67
    [svn:fx-4.0.0] 14695: rollback rev# 14687.
    jmurphy67 Level 1
      Revision: 14695
      Revision: 14695
      Author:   jimurphy@adobe.com
      Date:     2010-03-10 18:27:31 -0800 (Wed, 10 Mar 2010)
      Log Message:
      rollback rev# 14687.  The version was not supposed to be changed, there was a mistake in the CC config file that caused the version to be automatically updated.  This has no bearing on the release or the tags that have been created, this is merely housekeeping to keep the branch in order.
      QE notes: no
      Doc notes: no
      Bugs: no
      Reviewer:no
      Tests run: no
      Is noteworthy for integration: no
      Modified Paths:
          flex/sdk/branches/4.0.0/build.properties
          flex/sdk/branches/4.0.0/frameworks/projects/airframework/src/mx/core/Version.as
          flex/sdk/branches/4.0.0/frameworks/projects/airspark/src/spark/core/Version.as
          flex/sdk/branches/4.0.0/frameworks/projects/automation/src/mx/core/Version.as
          flex/sdk/branches/4.0.0/frameworks/projects/automation_air/src/mx/core/Version.as
          flex/sdk/branches/4.0.0/frameworks/projects/automation_dmv/src/mx/core/Version.as
          flex/sdk/branches/4.0.0/frameworks/projects/automation_flashflexkit/src/mx/core/Version.a s
          flex/sdk/branches/4.0.0/frameworks/projects/automation_spark/src/mx/core/Version.as
          flex/sdk/branches/4.0.0/frameworks/projects/automation_spark/src/spark/core/Version.as
          flex/sdk/branches/4.0.0/frameworks/projects/datavisualization/src/mx/core/Version.as
          flex/sdk/branches/4.0.0/frameworks/projects/framework/src/mx/core/Version.as
          flex/sdk/branches/4.0.0/frameworks/projects/rpc/src/mx/core/Version.as
          flex/sdk/branches/4.0.0/frameworks/projects/spark/src/spark/core/Version.as
          flex/sdk/branches/4.0.0/modules/compiler/src/java/flex2/tools/VersionInfo.java
